Applications and Utilities
This section provides an overview of the applications and utilities that you need to install and maintain Jamf Pro.
Jamf Pro Server
The Jamf Pro server is a web app that functions as the administrative core of Jamf Pro. The Jamf Pro server allows you to perform inventory and remote management and configuration tasks on managed computers and mobile devices. All other administrative applications in Jamf Pro communicate with the Jamf Pro server.
Jamf Pro Installer for Mac
The Jamf Pro Installer for Mac is a standard .pkg installation package that allows you to install and upgrade Jamf Pro on Mac. It is signed by Jamf.
To obtain the Jamf Pro Installer for Mac, log in to Jamf Account, navigate to Products > Pro, click the Downloads pop-up menu, choose "Mac", and then click Download for Mac.
Jamf Pro Server Tools
Jamf Pro Server Tools allows you to back up and restore the Jamf Pro database. It also allows you to restart Apache Tomcat and MySQL and modify their settings.
Jamf Pro Server Tools is installed automatically when you run the Jamf Pro Installer. It is located at:
/Library/JSS/bin/server-tools-gui.jar
Jamf Pro Server Tools also has a command-line interface (CLI). It is located at:
/Library/JSS/bin/jamf-pro
