Jamf Protect Package Management
If you have a Jamf Protect subscription and registered your Jamf Protect tenant with Jamf Pro, you can manage Jamf Protect packages directly from Jamf Pro. You can do the following:
Enable automatic package deployment.
Download the Jamf Protect package.
Upload the Jamf Protect package to Jamf Pro for deployment via policy.
Preparing the Jamf Protect PKG for Deployment
To prepare the Jamf Protect PKG for deployment to new computers, you can use one of the following methods:
Automatically deploy the PKG to any computers in the scope of a Jamf Protect plan configuration profile by selecting the Automatically deploy the Jamf Protect PKG with plans checkbox. This method is recommended and ensures that the Jamf Protect agent and plan are installed at the same time.
Download the latest version of the Jamf Protect PKG from Jamf Pro, and then upload it to Jamf Pro.
You must register your Jamf Protect tenant in Jamf Pro.For more information, see the Jamf Protect Integration with Jamf Pro section of this guide.
If you selected Automatically deploy the Jamf Protect PKG with plans, you can now configure the scope of your plans. No additional package upload steps are required.
If you clicked Download, the latest version of the Jamf Protect PKG downloads to your computer and can be uploaded to Jamf Pro.
