Jamf Connect Deployment Planning
You should thoroughly plan which Jamf Connect features you want to use in your environment before you create configuration profiles and deploy the Jamf Connect PKG. Depending on your user goals, you may need to prepare and package additional files for deployment alongside the Jamf Connect PKG.
Consider the following common user goals, corresponding Jamf Connect features, and their file requirements:
| User Goal | Jamf Connect Features | File Requirements |
| Display a splash screen during Automated Device Enrollment that displays information about the computer's enrollment process to users. | Notify screen | Notify script |
| Require users to agree to an acceptable use policy before accessing the computer. | Acceptable Use Policy screen | An acceptable use policy document or Apple policy banner |
| Display custom branding in the Jamf Connect login window and menu bar app for your organization. |
| Image files |
| Provide additional help for users with network connection issues when they click the Help button at the login window. | Login window local help file | Help file |
Planning Your Jamf Connect Deployment Needs
Before you continue with the Jamf Connect deployment process, ensure you complete the following planning steps:
After you have planned your Jamf Connect deployment, continue to the Packaging Files and Images with Composer to package your custom files.
