Jamf Protect Plans in Jamf Pro
If you have a Jamf Protect subscription and registered your Jamf Protect tenant with Jamf Pro, plans from your Jamf Protect tenant are available as computer configuration profiles in Jamf Pro. You can configure the scope of plan configuration profiles to deploy them to target computers.
Keep the following in mind when configuring scope for plan configuration profiles:
If you delete plan configuration profiles from Jamf Protect, the plans will re-appear without a scope the next time Jamf Pro syncs with Jamf Protect (every six hours).
You cannot edit the settings in a Jamf Protect plan from Jamf Pro. To edit a plan, navigate to the plan in your Jamf Protect tenant. Changes to a plan on computers are applied the next time the computer checks in with Jamf Protect.
If the Jamf Protect PKG is deployed without a plan configuration profile, computers will not check in with the Jamf Protect Cloud and the agent will not successfully monitor for threats. Configuring scope for your plans before deploying the Jamf Protect PKG is recommended.
To help you find plan configuration profiles synced from Jamf Protect on the computer configuration profiles pane, "(Jamf Protect)" is appended to each profile name that is synced.
Important: Plans that are manually uploaded to Jamf Pro will not appear in the Jamf Protect section of Jamf Pro. Deleting these plans configuration profiles and re-applying their scope to plans synced from Jamf Protect is recommended. This ensures you do not have duplicate versions of a plan in Jamf Pro and that scope is accurately configured. For more information about switching from manually uploaded plans to plans that are synced between Jamf Pro and Jamf Protect, see the Switching from Manually Uploaded Jamf Protect Plans to Synced Plans in Jamf Pro Knowledge Base article.
Configuring Scope for Jamf Protect Plans
You can configure the scope of available plan configuration profiles to deploy them to target computers.
Requirements
A Jamf Protect subscription
One or more plans in Jamf Protect
For instructions, see the Creating a Plan section in the Jamf Protect Administrator's Guide. -
Registration of your Jamf Protect tenant in Jamf Pro
For more information, see the Jamf Protect Integration with Jamf Pro section in this guide.
Procedure
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Jamf Applications.
Click Jamf Protect
In the Jamf Protect Plans table, click on the plan configuration profile you want to configure in the Profile column.
Note: You can click Sync to manually check Jamf Protect for plan updates. Jamf Pro automatically syncs with Jamf Protect every six hours.
Click Edit.
Click the Scope tab.
Configure the scope of your plan configuration profile.
Click Save.
The plan configuration profile is distributed to target computers the next time they check in with Jamf Pro. The scope also displays in the Scope column on the Jamf Protect page in Jamf Pro.
Related Information
To related information about Jamf Protect plans, see the Plans section in the Jamf Protect Administrator's Guide.
