Automated Enrollment
Requirements
To deploy devices using automated enrollment, you need:
  • Jamf Pro 9.82 or later
  • iOS devices supported by Apple Configurator 2
  • A Mac with Apple Configurator 2 installed
  • Enrollment in Apple's Device Enrollment Program (DEP)
For detailed Apple Configurator 2 requirements, see Requirements in Apple's Help documentation.
Deploy Devices Using Automated Enrollment
  1. Make sure Jamf Pro is integrated with DEP.
    See Integrating with the Device Enrollment Program in the Jamf Pro Administrator's Guide.
    To automatically apply a supervision identity as devices are enrolled using a PreStage enrollment, make sure a supervision identity is specified for the DEP or ASM instance in the PreStage.
    See "Adding a Supervision Identity to a DEP Instance" on the Supervision Identities page in the Jamf Pro Administrator's Guide.
  2. Create a PreStage enrollment and add devices to the scope.
    Make sure device supervision is selected in the PreStage. Also, select which steps in the iOS Setup Assistant to skip.
    See Mobile Device PreStage Enrollments in the Jamf Pro Administrator's Guide.
  3. In Apple Configurator 2, create a Wi-Fi configuration profile.
    See Create and edit configuration profiles in Apple's Help documentation.
  4. Create the blueprint that will be used to apply the profile.
    See About Blueprints in Apple's Help documentation.
  5. Prepare the blueprint.
    Make sure to select "Automated Enrollment", add the Wi-Fi configuration profile, and provide credentials to Jamf Pro if required in the PreStage enrollment.
    See Prepare devices using automated enrollment in Apple's Help documentation.
  6. Apply the blueprint to devices.
The devices connect to the network that is specified in the Wi-Fi configuration profile. Then they are enrolled with Jamf Pro and configured with the settings in the PreStage enrollment.
