Preparing to Reassign a Computer that is Registered with Microsoft Azure and Managed by Jamf Pro
Before reassigning a computer that is registered with Microsoft Azure and managed by Jamf Pro, it is recommended that you do the following:
Remove the Jamf-related components from the computer.
Delete the computer from the Microsoft Azure and Intune portals.
Removing Jamf Components from the Computer
For instructions on removing Jamf components from a managed computer, see the Components Installed on Managed Computers section in the Jamf Pro Administrator's Guide.
Deleting a computer from the Microsoft Azure and Intune Portal
To delete a computer that is managed by Jamf from the Microsoft Azure and Intune portals, do the following:
In the Microsoft Azure portal, navigate to Azure Active Directory > Devices > All Devices.
Select the device you want to delete.
Click Delete, and then click Delete again to confirm.
Navigate to Intune > Devices > All Devices.
The computer is removed from the Azure and Intune portal after Microsoft processes the request.
