Setting Up Jamf Pro
The first time you connect to the Jamf Pro server, the Jamf Pro Setup Assistant guides you through the following setup tasks:
  • Accept the license agreement.
  • Enter your activation code.
  • Create your first Jamf Pro user account.
  • Enter your Jamf Pro URL.
    The Jamf Pro URL is the URL that client applications, computers, and mobile devices will connect to when communicating with the Jamf Pro server.
After you complete the Jamf Pro Setup Assistant, you can click the setup tips that are displayed onscreen to start configuring commonly used settings.
You may also want to make changes to the following pre-configured settings to ensure they meet the needs of your organization. These settings are important because over time, they can significantly affect the size of your database and your levels of network traffic:
  • “Update Inventory” policy—Determines how often computers submit inventory to Jamf Pro.
    For more information, see "Computer Inventory Collection" in the Jamf Pro Administrator's
    Guide
  • Recurring check-in frequency—Determines the interval at which computers check in with Jamf Pro for available policies.
    For more information, see "Recurring Check-in Frequency" in the Jamf Pro Administrator's Guide.
  • Mobile device inventory collection frequency—Determines how often mobile devices submit inventory to Jamf Pro.
    For more information, see "Mobile Device Inventory Collection Settings" in the Jamf Pro Administrator's Guide.
Related Information
For related information, see the following article:
Network Ports Used by Jamf Pro
Learn about the network ports that you may need to configure when setting up Jamf Pro.
