Deleting an AD CS Certificate Authority
You can delete an AD CS certificate authority (CA) when viewing the CA's details in Jamf Pro.
A CA cannot be deleted from Jamf Pro if there are dependencies for the CA. For example, a CA cannot be deleted if it is being used in a configuration profile.
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Global Management.
Click PKI Certificates
Click View for the AD CS CA that you want to delete.
Click Delete
, and then click Delete again to confirm.
A list of dependencies is displayed if you cannot delete the CA. You must click OK and resolve the dependencies before deleting the CA.
