Integrating Jamf Connect with an Identity Provider
You must integrate Jamf Connect with your cloud identity provider (IdP).
This allows you to use Jamf Connect to create local accounts on computers alongside your Enrollment Customization configuration.
To integrate with IdPs using OpenID Connect authentication, the following workflow is generally used:
- Add Jamf Connect as an app in your IdP
Follow the IdP specific steps in this guide to add the app to your IdP. Adding the app will generate a Client ID, which is used to configure Jamf Connect.
Assign users and designate user roles
Add users or roles to the app as needed. Configuring a role allows you to determine whether users are created as a a standard or administrator user during account creation.
