Requirements
Mobile devices with iOS 13 or later, or iPadOS 13 or later
Computers with macOS 10.15 or later
To add a Single Sign-On Authentication PreStage Pane, you must have Single Sign-on enabled in Jamf Pro. For more information, see Enabling Single Sign-On in Jamf Pro.
Enabling Jamf Pro to pass user information to Jamf Connect requires Jamf Connect 1.12.0 or later. In addition, you must ensure Jamf Connect is configured and integrated with your identity provider (IdP).
To add an LDAP Authentication PreStage Pane, you need an LDAP server set up in Jamf Pro. For more information, see LDAP Directory Service Integration.
- In Jamf Pro, click Settings
in the top-right corner of the page. - In the Global Management section, click Enrollment Customization
. - Click New
. - Enter a display name and description for the Enrollment Customization configuration.
- Choose a site to add the Enrollment Customization configuration to from the Site pop-up menu.
This allows you to add the configuration to a PreStage enrollment in that same site.
Note: If you have site access only, the profile is assigned to the applicable site automatically and the Site pop-up menu is not displayed.
- Click Add Pane, and then do the following:
- Enter a display name for the pane.
- Choose from the Pane Type.
- Enable the Enable Jamf Pro to pass user information to Jamf Connect switch.
- Use the Account Name and the Account Full Name fields to map the user's attributes from the SAML token sent from your IdP to the local account Jamf Connect creates.
- Click Add.
- (Optional) Add additional PreStage Panes to the Enrollment Customization configuration as needed.
You can drag and drop PreStage Panes to change the PreStage pane order. If you added a Single Sign-On Authentication PreStage Pane and a Text PreStage Pane, the transition between each type of pane occurs when the user authenticates in the IdP login screen or uses the navigational buttons.
- Click the Branding and Preview tab to customize the enrollment experience and configure the settings on the page.
Once a change is made, it automatically displays in the preview field.
- Click Save
You can add the configuration to a PreStage enrollment. For more information, see Deploying Jamf Connect Using a Jamf Pro PreStage Enrollment.
Note: You cannot delete an Enrollment Customization configuration if the configuration is included in a PreStage enrollment. To delete the configuration, you must first remove it from the PreStage.
