Configuring Settings for Jamf Connect
Beginning with Jamf Pro 10.18.0, you can create a computer configuration profile that configures Jamf Connect settings with the Applications & Custom Settings payload. This payload allows you to select Jamf Connect apps, automatically generate a PLIST file, and scope it to target computers.
Alternatively, you can configure Jamf Connect with the Jamf Connect Configuration app.
Note: If deployed during a PreStage Enrollment, your configuration profile must be signed.
Configuring Jamf Connect in Jamf Pro
In Jamf Pro, click Computers at the top of the page.
Click Configuration Profiles.
Click New.
Use the General payload to configure basic settings, including the level at which to apply the profile and the distribution method. Only payloads and settings that apply to the selected level are displayed for the profile. To distribute the profile during enrollment using a computer PreStage enrollment, ensure you create a computer-level configuration profile.
For more information about distributing configuration profiles during enrollment, see Computer PreStage Enrollments in the Jamf Pro Administrator's Guide. -
Click the Applications & Custom Settings payload and do the following:
Select Configure Settings under Creation Method.
Choose "Jamf Repository" from the Source pop-up menu.
Select the preference domain of the Jamf Connect app you want to configure from the Preference Domain pop-up menu.
Select the Jamf Connect version to configure in the Version pop-up menu. Make sure the configured version matches the version installed on computers.
Configure Jamf Connect settings as needed. To determine which settings are required, see the Jamf Connect Administrator's Guide.
Important: In addition to the minimum required settings, you must also configure the ROPGTenantID key to specify your identity provider's tenant ID.
Click the Scope tab and configure the scope of the profile.
For more information, see Scope in the Jamf Pro Administrator's Guide.Note: To distribute the profile during enrollment using a computer PreStage enrollment, ensure the scope of the profile contains the computers that are in the scope of the PreStage enrollment. For more information about distributing configuration profiles during enrollment, see Computer PreStage Enrollments in the Jamf Pro Administrator's Guide.
Click Save.
Configuring Jamf Connect with Jamf Connect Configuration
You can create a configuration profile for Jamf Connect using the Setup Assistant. The Setup Assistant can generate a configuration profile that includes the minimum keys needed to use Jamf Connect with your IdP. After using the Setup Assistant, you can either immediately save the configuration profile or configure additional settings.
In Jamf Connect Configuration, click New.
Do the following in the Setup Assistant window:
Choose your cloud identity provider (IdP) from the Identity Provider pop-up menu. Your IdP's required settings will display.
Configure the required fields for your IdP.
Notes:
Required keys vary based on your IdP.
In addition to the minimum required settings, you must also configure the ROPG Tenant setting to specify your identity provider's tenant ID.
After configuring required settings, you can do one of the following:
Click Save to generate and save a configuration profile.
If saving as a .mobileconfig file, complete the configuration profile metadata fields.Note: When saving directly from the Setup Assistant, your configuration profile is saved on your computer but not stored in the Jamf Connect Configuration sidebar. To continue editing your configuration profile, click Advanced Setup or manually import your configuration profile back into the app.
Click Advanced Setup to configure additional settings, and then click Save to generate and save a configuration profile.
The configuration is saved to the sidebar for further editing and testing.
Related Information
For additional information about required settings, see the following sections of the Jamf Connect Administrator's Guide:
