Managing Legacy Kernel Extensions in macOS Using Jamf Pro
With macOS 11, additional steps are needed to load and use legacy kernel extensions. This requires user approval in Security & Privacy preferences and computers must be restarted to load the kernel extension into a kernel cache. You can use the technologies in Jamf Pro to complete this additional process using MDM.
On Mac computers with Apple silicon, Rosetta 2 does not translate kernel extensions built for Intel processors. Ensure your app or software supports Apple silicon.
RestartDevice
MDM command to load the legacy kernel extension cache. This process looks similar to the following:- 1. Create a computer configuration profile with an Approved Kernel Extensions payload.
- The profile allows you to pre-approve the required kernel extensions for the software you are installing on target computers. When the profile is installed on the computers, the kernel extensions specified in the profile are can be loaded on target computers.
- 2. Restart the computer using one of the following methods:
- You can use the MDM Restart with Kernel Cache Rebuild option in Jamf Pro to restart the computer after installing the software.Note:
Restarting the computer using the MDM Restart with Kernel Cache Rebuild option in Jamf Pro is the recommended restart method.
General Requirements
To manage required legacy kernel extensions on computers with macOS 11 or later, computers must be enrolled with Jamf Pro 10.28.0 or later.
Bootstrap token for target computers escrowed with Jamf Pro
The computer requests this information from Jamf Pro before the configuration profile can be installed or the RestartDevice MDM command can be executed on the computer.
The Allow remote management of kernel extensions and automatic software updates option enabled in the Startup Security Utility (in macOS Recovery).
For more information about how to enable this setting, see Change startup disk security settings on a Mac with Apple silicon from Apple's support website.
Note:Enrolling computers with Jamf Pro via a PreStage enrollment can automatically enable this setting. No further action is needed.
Approving Kernel Extensions Using a Configuration Profile
- Log in to Jamf Pro.
- Click Computers at the top of the page.
- Click Configuration Profiles.
- Click New.
- Use the General payload to configure basic settings for the profile, including the level at which to apply the profile and the distribution method.
- Select the Approved Kernel Extensions payload, click Configure, and do the following:
Restarting Computers using MDM Restart with Kernel Cache Rebuild
You can restart computers by using the MDM Restart with Kernel Cache Rebuild option in Jamf Pro.
Restarting Computers using the Jamf Pro API
RestartDevice
MDM command to computers using the Jamf Pro API and Terminal on a computer that can contact the Jamf Pro server.Endpoints that include the term "preview" are subject to future changes.
The process involves the following steps using the Jamf Pro API:
Obtaining the management ID of target computers
Sending the
RestartDevice
MDM command to target computers.
These steps should be completed after the software that requires kernel extension permission has been installed on the target computer.
Obtaining the Management ID
curl --location --request GET 'https://YOUR_JAMF_PRO_URL/api/preview/computers' --header 'Authorization: Bearer YOUR_BEARER_TOKEN'
The response contains information about the computer, including the management ID.
| Retrieves a specified page in the response |
| Increases the number of computers contained in each page of the response. The maximum number is 2000. |
curl --location --request GET 'https://YOUR_JAMF_PRO_URL/api/preview/computers?page=2&page-size=2000' --header 'Authorization: Bearer YOUR_BEARER_TOKEN'
This response will return the second page of computers. Each page lists 2,000 computers.
Sending the RestartDevice MDM command
You can enter the management ID of the target computer into a command to restart the computer via MDM.
curl --location --request POST 'https://JAMF_PRO_URL/api/preview/mdm/commands' \
--header 'Authorization: Bearer JAMF_PRO_AUTH_TOKEN' \
--header 'Content-Type: application/json' \
--data-raw '{
"clientData": [
"managementId": "A9C3D1F0-DCB2-4D52-84C6-D5AD60140B04",
"clientType": "COMPUTER"
"commandData": {
"commandType": "RESTART_DEVICE",
"rebuildKernelCache": "true",
"kextPaths": [
"kext1",
"kext2",
"kext3"
"notifyUser": "true"
NotifyUser
key is set to true, the following scenarios dictate how the notification is displayed to users and when the computer restarts:If no user is logged in to the computer, the computer immediately restarts without displaying a notification
If a user is currently logged in to the computer, a persistent Notification Center banner is displayed requesting them to restart the computer.
If Fast User Switching is enabled on the computer and the login screen is displayed, a notification is displayed to the next user that logs in requesting them to restart the computer regardless of any currently logged in user status.
If the computer does not have macOS 11.3 or later, the computer immediately restarts without displaying a notification.
If the user does not restart the computer, the RestartDevice
MDM command is still acknowledged as successful in the computer's management history information in Jamf Pro.
