Converting the MySQL Database Storage Engine from MyISAM to InnoDB Using the Jamf Pro Server Tools Command-Line Interface
The InnoDB conversion process may considerably increase the size of your MySQL database. Before converting the database, it is recommended that you have at least as much free disk space as the current database size, as well as adequate RAM (memory) for the server, as InnoDB will require some memory-intensive operations. If adequate system resources are not available on the server, either memory or storage, do not continue this process until resources have been addressed.
Converting the MySQL storage engine to InnoDB involves the following steps:
Ensuring You Have the Latest Version of the Jamf Pro Server Tools CLI
Confirming Database Information
Configuring the Jamf Pro Server Tools CLI
Configuring InnoDB Settings
Stopping Apache Tomcat
Backing Up the Database
Converting to InnoDB
General Requirements
Local or remote access to the server hosting the Jamf Pro database
Local administrator credentials
Step 1: Ensuring You Have the Latest Version of the Jamf Pro Server Tools CLI
If you have already installed the Jamf Pro Server Tools CLI, ensure that you have the latest version by doing the following:
Methods to Download Install Jamf Pro Server Tools CLI
Installing the Jamf Pro Server Tools CLI Included in the Jamf Pro Installer (Jamf Pro 10.7.0 or later)
If you are converting the MySQL storage engine to InnoDB and upgrading to the latest version of Jamf Pro, you may use the Jamf Pro installer to install the Jamf Pro Server Tools CLI. Be aware that the version of the Jamf Pro Server Tools CLI installed via a package manager will always be the latest and may be newer than the one included in the Jamf Pro installer. For more information, see "Downloading the Jamf Pro Server Tools CLI Using a Package Manager" below.
Linux: /usr/local/jss/bin/jamf-pro
Windows: C:\Program Files\JSS\bin\jamf-pro.exe
- Red Hat Enterprise Linux
rpm --import https://archive.services.jamfcloud.com/gpg-public-key.asc yum-config-manager --add-repo=https://archive.services.jamfcloud.com/rpm/ yum install jamf-pro-server-tools
- Downloading the Jamf Pro Server Tools CLI Using a Browser
- To manually download the Jamf Pro Server Tools CLI binary for your platform from a browser, go to the following webpage: https://archive.services.jamfcloud.com/#jamf-pro-server-tools/release/latest/
- Other Downloading Options
- For more information and options for installing the Jamf Pro Server Tools CLI, see the The Jamf Pro Server Tools Command-Line Interface article.
You can copy the jamf-pro binary to other servers in your environment if you want to use the CLI on a different server. There are no additional requirements or dependencies.
Step 2: Confirming Database Information
Database name
Database user
Database user's password
the Jamf Pro Apache Tomcat web application to connect to the MySQL database, and
the Jamf Pro Server Tools utility to connect to and manage the MySQL database
When using the Jamf Pro Server Tools CLI to set the values for these connections, a different command must be executed for each connection.
For an existing Jamf Pro installation, this information should already be set in the DataBase.xml file (for the connection between the Jamf Pro web application and the MySQL database). You will need these same values to configure the connection between Jamf Pro Server Tools and the MySQL database (see below). If these values are unknown to you, you may obtain them from the DataBase.xml file.
Linux servers: /usr/local/jss/tomcat/webapps/ROOT/WEB-INF/xml
Windows servers: C:\Program Files\JSS\Tomcat\webapps\ROOT\WEB-INF\xml
Step 3: Configuring the Jamf Pro Server Tools CLI
In a default installation of the Jamf Pro Server Tools, the database information from Step 3 is already set to a default value in the CLI configuration.
Before converting the database engine from MyISAM to InnoDB, configure two InnoDB-specific MySQL settings. The two settings are innodb_buffer_pool_size
and innodb_file_per_table
This setting controls how much RAM is available for the InnoDB engine to cache table and index data and must be configured before attempting the conversion. The recommended InnoDB buffer pool size is around 50 to 70% of the total system memory for dedicated database servers. However, if the Jamf Pro database server is also hosting Tomcat, calculate this value to be 50 to 70% of the remaining system memory, after accounting for how much is already allocated to the Tomcat service, the operating system, and any other running services on the server.
For example, a server running both Tomcat and MySQL with 16 GB of RAM total has 8 GB allocated to the Tomcat service and 4 GB has been set aside for the system and other processes. 4 GB remains from the original total, so the calculation would be to allocate anywhere from 2 to 3 GB to the InnoDB buffer pool size setting.
jamf-pro database config set --innodb-buffer-pool-size <value>
jamf-pro database config set --innodb-buffer-pool-size 2048MB
jamf-pro database config set --innodb-buffer-pool-size 2GB
- To set the innodb_file_per_table to true, execute the following command:
jamf-pro database config set --innodb-file-per-table true
- Execute the following command to restart the MySQL service:
jamf-pro database restart
Step 4: Stopping Tomcat on the Jamf Pro Server
For Linux servers, sudo
privileges are required.
For Windows servers, the jamf-pro
commands must be run from the directory where the executable is stored. Reference Step 4 for instructions on navigating to the correct directory.
jamf-pro server stop
If Tomcat is running on a different server or this is a clustered environment, Tomcat must be stopped on all nodes. For information on starting and stopping Tomcat on the server hosting the Jamf Pro web app, see the Starting and Stopping Tomcat article.
Step 5: Backing Up the Database
Step 6: Converting the Database to InnoDB
After the pre-conversion process is complete, all database tables will be converted from MyISAM to InnoDB. This process may take some time.
A message stating that the conversion is complete will be displayed when the process has finished. At this point it is recommended to create a new database backup (see Step 7 above) prior to starting Tomcat again on the server.
Step 7: Getting Help and Troubleshooting
jamf-pro help
Similarly, using the --help
flag with any jamf-pro
subcommand will display usage information about that command:
jamf-pro database --help
On Linux, some CLI commands may require sudo
. If you receive an error similar to "jamf-pro: command not found", the sudopath
may not be configured properly. To resolve this issue, run sudo
using the full path to the jamf-pro binary. For example:
sudo /usr/local/jss/bin/jamf-pro database convert-to-innodb
If you receive an error similar to "Error: database config file not found", the my.cnf or my.ini file has not been found by the CLI tool. You will need to verify that it is present on the system per Step 2 above.
jamf-pro database config set --innodb-buffer-pool-size 1024M
