Configuring Jamf Pro to use an HTTP Proxy Server for Communications with Automated Device Enrollment and Volume Purchasing
This article explains two ways to configure Jamf Pro to use an HTTP proxy server for communications with Automated Device Enrollment (formerly DEP) and Volume Purchasing (formerly VPP). Jamf Pro can either use HTTP proxy server settings stored in the jamfsoftware database or use settings specified in the JVM (Java Virtual Machine) properties. Follow the procedure below for your desired method.
Configuring Jamf Pro to use HTTP Proxy Server Settings Contained in the Jamfsoftware Database
Configuring Jamf Pro to Use HTTP Proxy Server Settings Contained in the JVM Properties
If you have not configured the HTTP proxy server settings (http.proxyHost, http.proxyPort, http.proxyUser, and http.proxyPassword) in your JVM properties, you can use the method below to configure Jamf Pro to use these settings in your JVM properties.
Linux
Windows
Additional Information
For more information about integrating Jamf Pro with Automated Device Enrollment and Volume Purchasing, see the following sections in the Jamf Pro Documentation:
