User-Initiated Enrollment for Mobile Devices
You can allow users to enroll mobile devices by having them log in to an enrollment portal where they are prompted to install the MDM profile and certificates. You can either choose to provide users with an enrollment URL in the way that best fits your environment, have the user authenticate to their device with a Managed Apple ID (Account-Driven User Enrollment), or send an enrollment invitation to users.
General Requirements
To allow mobile devices to be enrolled with user-initiated enrollment, you need:
  • A push certificate in Jamf Pro (For more information, see Push Certificates.)
  • User-initiated enrollment enabled (For more information, see User-Initiated Enrollment Settings.)
  • (Account-Driven User Enrollment only) Mobile devices with iOS 15 or later, or iPadOS 15 or later
  • (User Enrollment only) Mobile devices with iOS 13.1 or later, or iPadOS 13.1 or later
  • (LDAP log in only) An LDAP server set up in Jamf Pro (For more information, see Integrating with LDAP Directory Services.)
Providing an Enrollment URL to Users
Note: For Account-Driven User Enrollment, the user is redirected to the enrollment portal and prompted to install the MDM profile on their device after they authenticate to their device with a Managed Apple ID. Because this enrollment method is initiated when the user signs in with the Managed Apple ID, you do not have to provide users with the enrollment URL to direct them to the enrollment portal.
To direct users to the enrollment portal, you need to provide them with the enrollment URL. The enrollment URL is the full URL for the Jamf Pro server followed by “/enroll”. For example:
  • https://instancename.jamfcloud.com/enroll (hosted in Jamf Cloud)
  • https://jamf.instancename.com:8443/enroll (hosted on-premise)
You can provide the enrollment URL to users in the way that best fits your environment.
Note: Users must use Safari to access the enrollment URL.
Users can log in to the enrollment portal using an LDAP directory account or a Jamf Pro user account. When a user logs in with an LDAP directory account, user and location information is submitted to Jamf Pro during enrollment. When a user logs in with a Jamf Pro user account, it allows an LDAP user to be assigned to the mobile device.
Sending a Mobile Device Enrollment Invitation for User-Initiated Enrollment
You can send an email or SMS invitation that contains the enrollment URL from Jamf Pro to one or more users enrolling institutionally owned mobile devices. Users tap the enrollment URL in the email or SMS message to access the enrollment portal. Enrollment invitations give you more control over user access to the enrollment portal by allowing you to do the following:
  • Set an expiration date for the invitation
  • Require users to log in to the portal
  • Allow multiple uses of the invitation
  • Add the mobile device to a site during enrollment
  • View the status of the invitation
Before you configure the invitation, make sure you have the email addresses or phone numbers of the users you want to send the invitation to.
Note: You cannot enroll personally owned devices with an enrollment invitation. You must provide the enrollment URL to those users by some other means.
Requirements
To send an enrollment invitation to mobile devices, you need an SMTP server set up in Jamf Pro. (For more information, see Integrating with an SMTP Server.)
Procedure
  1. Log in to Jamf Pro.
  3. Click Enrollment Invitations.
  4. Click New images/download/thumbnails/86838084/Icon_New_Button.png .
  5. Select User-Initiated Enrollment as the enrollment method.
  6. Follow the onscreen instructions to send the enrollment invitation.
An enrollment invitation is immediately sent to the email addresses or phone numbers you specified.
You can view the status of the enrollment invitation in the list of invitations.
Viewing Mobile Device Enrollment Invitation Usage
You can view a list of mobile devices that were enrolled with a specific enrollment invitation.
  4. Click the enrollment invitation you want to view usage for.
  5. Click View Enrolled Mobile Devices images/download/thumbnails/80749108/preview-content.png .
A list of mobile devices enrolled with the invitation is displayed.
Related Information
