Simple Volume Content Searches
A simple volume purchasing content search functions like a search engine, allowing you to quickly search the apps and books in Jamf Pro for a general range of results.
Volume purchasing content searches are based on the name of the app or book you are searching for and display the following information:
Content Name—Name of the app or book
Location—Volume purchasing location used to purchase the content
Content Type—Type of content
Total Content—Total content that has been purchased with the volume purchasing location
In Use—Number of apps or books assigned to computers, mobile devices, or users
Volume Assignments—Number of volume assignments that the content is associated with
As an alternative, you can create an advanced volume content search that uses detailed search criteria. Advanced volume content searches can be saved for later use. For more information, see Advanced Volume Content Searches.
Search Syntax
This section explains the syntax to use for search functions. In general, searches are not case-sensitive.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. For more information about configuring account preferences, see Jamf Pro User Accounts and Groups.
The following table explains the syntax you can use for search functions:
Search Function |
Usage |
Example |
Return all Results |
Use an asterisk (*) without any other characters or terms, or perform a blank search. |
Perform a search for “*” or leave the search field empty to return all results. |
Perform Wildcard Searches |
Use an asterisk after a search term to return all results with attributes that begin with that term. |
Perform a search for “key*” to return all results with names that begin with “key”. |
Use an asterisk before a search term to return all results with attributes that end with that term. |
Perform a search for “*note” to return all results with names that end with “note”. |
Use an asterisk before and after a search term to return all results that include that term. |
Perform a search for “*ABC*” to return all results that includes “ABC”. |
Include Multiple Search Terms |
Use multiple search terms separated by a comma (,) to return all results that include those search terms. |
Perform a search for “key*, *note” to return all results that begins with “key” and ends with “note”. |
Exclude a Search Term |
Use a hyphen (-) before a search term to exclude results that include the term. |
Perform a search for “ABC*, -*note” to return all results with names that begin with “ABC” except for those that end with “note”. |
Performing a Simple Volume Purchasing Content Search
Log in to Jamf Pro.
Click Computers, Devices, or Users at the top of the page.
Click Search Volume Content.
Enter one or more search terms in the field provided.
Press the Enter key.
Viewing Where Content is Assigned
You can view the computers, mobile devices, or users that content is assigned to.
Log in to Jamf Pro.
A list of content is displayed. -
To view where the content is assigned, click the number displayed in the In Use column.
Computers that have the content assigned to them are listed on the Computers pane.
Mobile devices that have the content assigned to them are listed on the Mobile Devices pane.
Users that have the content assigned to them are listed on the Users pane.
Viewing the Volume Assignments that Content is Associated With
You can view the volume assignments that content is associated with.
Log in to Jamf Pro.
To view the Volume assignments that the content is assigned to, click the number displayed in the Volume Assignments column.
Related Information
Volume Content Reports
Find out how to export the data in your search results to different file formats. -
User-Assigned Volume Assignments
Find out how to assign content to users for managed distribution. -
Device-Assigned Managed Distribution
Find out how to assign content to computers and mobile devices for managed distribution.
