Remote Commands for Mobile Devices
The remote commands available in Jamf Pro allow you to remotely perform tasks on a mobile device.
You can send a remote command to a single mobile device. Some commands can also be sent to multiple devices at once using mass actions. For more information, see Mass Actions for Mobile Devices.
Note: The remote commands available for a particular device vary depending on the device ownership type, device platform, device type, and OS version. For more information, see Mobile Device Management Capabilities.
The following table describes the remote commands that you can send from Jamf Pro:
Remote Command
Description
Available as a Mass Action
iOS Device Requirements
Personally Owned iOS Device Support
Update Inventory
Prompts the mobile device to contact Jamf Pro and update its inventory
images/download/thumbnails/85400356/checkmark.png
Lock Device
Locks the mobile device
If the mobile device has a passcode, the user must enter it to unlock the device.
(Optional) Displays a message on the mobile device when it locks. This message is only sent if the mobile device has a passcode.
(Optional) Displays a phone number on the mobile device when it locks. The phone number is only displayed if the mobile device has a passcode.
images/download/thumbnails/85400356/checkmark0.png
Clear Passcode
Removes the passcode from the mobile device
If a configuration profile with a Passcode payload is installed on the device, the user is prompted to create a new passcode.
Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared, you must put the device in DFU mode to disable Lost Mode.
Clear Screen Time Passcode
(This command was previously called Clear
Restrictions.)
Removes the Screen Time passcode from a device
  • iOS 8 or later
  • Supervised
Update Passcode Lock Grace Period
Sets the amount of time that a device's screen can be locked before requiring a passcode to unlock it
  • iOS 9.3 or later
  • Enrolled via a PreStage enrollment with Shared iPad enabled
Unmanage Device
Stops communication between the mobile device and the Jamf Pro server, which means you can no longer perform management tasks on the device
When you unmanage a device, the following items are removed from the device:
  • MDM profile
  • Device certificate
  • Self Service
  • Any configuration profiles that were distributed with Jamf Pro
  • Any managed apps that were distributed with the Remove app when MDM profile is removed checkbox selected
Note: Although an unmanaged device will no longer submit inventory, its inventory record remains in Jamf Pro.
Note: Only personally owned mobile devices enrolled using User Enrollment can execute the Unmanage Device command.
Wipe Device
Permanently erases all data on the device and deactivates the device. This command is available for both iOS and Apple TV devices (tvOS 10.2 or later).
Optionally, you can:
  • Clear Activation Lock on the device
  • Retain cellular data plans (iOS 11 or later)
  • Suppress Proximity Setup on the device (iOS 11.3 or later)
Note: Wiping a device does not remove the device from Jamf Pro or change its inventory information.
To restore the device to the original factory settings, you must manually reactivate the device.
Set Shared iPad User Space
(This command was previously called Set Storage Quota Size)
Sets the Shared iPad user space on each iPad. You can set the following:
  • Number of Users—You can enter the maximum number of users that can be stored with the iPad. You can specify up to 99 users. This limits the number of user accounts that can be stored locally on the iPad.
  • Storage Quota Size—You can specify the maximum amount of storage (MB) allocated for each user on devices with iPadOS 13.4 or later. This overrides the maximum number of users. Quota size is dependent on the device's storage capacity and must meet the following limitations:
    • Devices with a storage capacity of 64 GB or greater must have 2048 MB or greater entered for storage space.
    • Devices with a storage capacity of 32 GB or greater must have 1024 MB or greater entered for storage space.
All users must be logged out and removed from the device before this command can be sent.
Note: If devices are upgraded to iPadOS 13.4 or later, it is recommended that the device is wiped before setting the storage quota size.
  • iPadOS 13.4 or later
  • Supervised
Restart Device
Restarts a device. This command is available for both iOS and Apple TV devices (tvOS 10.2 or later).
(Optional) Clears the passcode on the device. If this option is chosen, the Clear Passcode command is sent to the device before the device is restarted.
Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared using the Clear Passcode command, you must put the device in DFU mode to disable Lost Mode.
  • iOS 10.3 or later
  • Supervised
Send Blank Push
Sends a blank push notification, prompting the device to check in with Apple Push Notification service (APNs)
Set Wallpaper
Sets an image or photo as wallpaper for the Lock screen, Home screen, or both screens on a supervised device
You can upload an image file or choose an existing image file.
  • iOS 7 or later
  • Supervised
Enable/Disable Voice Roaming
Enable/Disable Data Roaming
Enables/disables voice or data roaming on the device
Note: Disabling voice roaming automatically disables data roaming.
  • iOS 5 or later
  • Cellular capability
Update OS Version
Updates the OS version on supervised devices
You can update the OS version for iOS or tvOS devices using the following options:
  • Target Version—You can choose to update the OS version to the latest version based on device eligibility or you can update to a specific version.
Note: Updating to a specific OS version requires iOS 12 or later and tvOS 12.2 or later.
  • iOS Update Action—You can choose to download the update for users to install, or to download and install the update and restart devices after installation.
Note: This option applies to iOS devices only.
This command is only available as a mass action.
For more information, see the Updating iOS Best Practice Workflow for Jamf Pro.
  • iOS 9 or later
  • tvOS 12 or later
  • Supervised
  • Enrolled via a PreStage enrollment (devices with iOS 9-10.2)
  • No set passcode
Log Out User
Logs out the currently logged in user for Shared iPad only
  • iOS 9.3 or later
  • Supervised
Enable/Disable Lost Mode
Enables/disables Lost Mode on the device
Lost Mode locks the device and displays your custom messaging on the device's Lock screen. Global Positioning System (GPS) coordinates for the device's approximate location are also displayed in the inventory information for the device.
  • iOS 9.3 or later
  • Supervised
(Optional) Always enforces Lost Mode on the device. This option ensures Lost Mode is enabled after an enrollment event has completed. When selected, Lost Mode can be only disabled in Jamf Pro.
(Optional) Plays a sound on the lost device.
  • iOS 10.3 or later
  • Supervised
  • Lost Mode enabled
Update Location
Updates the GPS coordinates collected for a mobile device in Lost Mode
  • iOS 9.3 or later
  • Supervised
  • Lost Mode enabled
Enable/Disable Diagnostic and Usage Reporting
Enable/Disable App Analytics
Enables/disables the sending of diagnostic and usage data to Apple
Enables/disables the sending of app analytics data to Apple
Note: Disabling diagnostic and usage reporting automatically disables app analytics.
  • iOS 9.3 or later
  • Supervised
Shut Down Device
Shuts down the device
(Optional) Clears the passcode on the device. If this option is chosen, the Clear Passcode command is sent to the device before the device is shutdown.
  • iOS 10.3 or later
  • Supervised
Enable/Disable Bluetooth
Enables/disables Bluetooth on the device
  • iOS 11.3 or later
  • Supervised
Set Activation Lock
Enable Activation Lock directly on a device
Allow user to enable Activation Lock on the device
Note: If Activation Lock is enabled on the device when this command is sent, Jamf Pro automatically clears the Activation Lock before allowing the user to re-enable it.
Disable and prevent Activation Lock
For more information, see the Leveraging Apple's Activation Lock Feature with Jamf Pro article.
  • Supervised
  • In Apple School Manager or Apple Business Manager
Enable/Disable Personal Hotspot
Enables/disables the Personal Hotspot on the device
iOS 7 or later
Manage Jamf Parent
Allows you to remove app restrictions set by Jamf Parent on students' school-issued devices or remove Jamf Parent management capabilities. Removing Jamf Parent management capabilities prevents Jamf Parent from managing the student device until the parent scans the QR code again. To remove Jamf Parent restrictions on student devices, you need a Jamf Pro user account with the "Remove restrictions set by Jamf Parent" privilege.
For more information, see Jamf Parent Integration with Jamf Pro.
Note: This remote command is available as the following separate mass actions:
  • Remove restrictions set by Jamf Parent
  • Remove Jamf Parent management capabilities
Supervised
Remove restrictions set by Jamf Teacher
Allows you to remove restrictions set by Jamf Teacher on students' school-issued devices. This option is only displayed if Jamf Teacher is enabled in the Jamf Teacher settings. To remove Jamf Teacher restrictions on student devices, you need a Jamf Pro user account with the "Remove restrictions set by Jamf Teacher" privilege.
For more information about how to enable Jamf Teacher, see Jamf Teacher Integration with Jamf Pro.
  • iOS 10.11 or later
  • Supervised
Refresh Cellular Plans
Refreshes a device’s cellular plan by querying a carrier URL for active eSIM cellular plan profiles
Note: The device and carrier must support eSIM. For more information, see Find wireless carriers that offer eSIM service from Apple's support website.
  • iPads with iPadOS 13 or later
  • iPhones with iOS 14 or later
Renew MDM Profile
Renews the MDM profile on the mobile device, along with the device identity certificate. The device identity certificate has a default expiration period of two years.
Note: The Renew MDM Profile remote command is automatically issued when the built-in CA is renewed. The MDM profile will be renewed during the next mobile device check-in. For more information, see "Renewing the Built-in CA" in PKI Certificates.
Set Time Zone
Sets a time zone on a device
  • iOS 14 or later
  • tvOS 14 or later
  • Supervised
Recommend Software Update Version
Allows you to recommend a software version in the Software Update settings that users are allowed to install. You can recommend the following:
  • Latest major version only
  • Latest minor version only
  • Any available version
The default setting is to recommend any available version. If this is selected, then both updates for the latest major version and the latest minor version or displayed simultaneously, if available.
For more information about Software Updates, see Managing Software Updates for Apple Devices in Apple's Mobile Device Management Settings.
  • iOS 14.5 or later
  • iPadOS 14.5 or later
  • Supevised
Personal Device Profiles Only (Deprecated)
Wipe Institutional Data
Disclaimer: Personal device profiles have been deprecated. User Enrollment is the Apple-preferred method for enrolling personally owned devices in a Bring Your Own Device (BYOD) program. For information on enrolling personally owned iOS or iPadOS devices with Jamf Pro, see the Building a BYOD Program with User Enrollment and Jamf Pro technical paper. For legacy documentation about Personal Device Profiles, see version 10.27.0 or earlier of the Jamf Pro Administrator's Guide.
Permanently erases institutional data and settings on the device
On a personal mobile device, the following items are removed:
  • MDM profile
  • Personal Device Profile, including any institutional settings and managed apps
On personal mobile devices, the Wipe Institutional Data command makes the device unmanaged. This stops communication between the device and the Jamf Pro server, which means you can no longer perform management tasks on the device.
Note: Only personally owned mobile devices enrolled using Personal Device Profiles can run the Wipe Institutional Data command.
Sending a Remote Command to a Mobile Device
  1. Log in to Jamf Pro.
  3. Perform a simple or advanced mobile device search.
  4. Click the mobile device you want to send the remote command to.
    If you performed a simple search for an item other than mobile devices, you must click Expand images/download/thumbnails/85400356/Icon_Expand.png next to an item to view the devices related to that item.
  5. Click the Management tab, and then click the button for the remote command that you want to send.
    Depending on the command selected, additional options may be available.
The remote command runs on the mobile device the next time the device contacts Jamf Pro.
After the command is sent, you can do the following on the History tab:
  • To view the status of a remote command, use the Management history pane to view completed, pending, or failed commands.
  • To cancel a remote command, click Pending Commands. Find the command you want to cancel, and click Cancel across from it.
Related Information
For related information about performing mobile device searches, see the Simple Mobile Device Searches or Advanced Mobile Device Searches sections of this guide.
