Mobile Device Management Information
Jamf Pro allows you to view management information for each mobile device, including group memberships, Jamf Pro objects that have the mobile device in scope, and more. The following table lists what management information you can view for a mobile device:
Category |
Notes |
Management Commands |
Configuration Profiles |
If your environment uses Shared iPad, you can view a list of configuration profiles for a specific user on that device. |
Activation Lock Bypass |
Apps |
eBooks |
Mobile Device Groups |
Note: The management information available for a particular device varies depending on the device ownership type, device type, and iOS version. For more information, see Mobile Device Management Capabilities.
Viewing Management Information for a Mobile Device
Log in to Jamf Pro.
Click Devices at the top of the page.
Perform a simple or advanced mobile device search.
Click the device you want to view management information for.
If you performed a simple search for an item other than mobile devices, you must click Expandnext to an item to view the devices related to that item.
Click the Management tab, and then click the category you want to view management information for.
A list of results is displayed.
Related Information
For related information about managing mobile devices, see the following sections in this guide:
Group Management
Learn how to use smart or static groups to manage mobile devices. -
Simple Mobile Device Searches
Learn how to find management information using simple mobile device searches. -
Advanced Mobile Device Searches
Learn how to find management information using advanced mobile device searches.
