Mobile Device Management Capabilities
Jamf Pro can be used to enroll and manage the following devices:
iOS devices
iPadOS devices
tvOS devices
Personally owned iOS devices
The management capabilities available for a particular device vary depending on the device ownership type, device type, and OS version.
This section includes information for OS versions that meet the minimum system requirements for managed mobile devices in Jamf Pro. For information on these requirements, see "System Requirements" in the Jamf Pro Release Notes.
Note: This section provides an overview of mobile device management capabilities by OS version and does not account for additional feature-specific requirements. For information on feature-specific requirements, see the documentation for that feature.
Management Capabilities for Mobile Devices
The following table provides an overview of the management capabilities available with Jamf Pro for iPad, iPhone, and iPod touch devices by iOS version:
iOS Version |
11 |
12 |
131 |
141 |
151,8 |
Personally Owned iOS Device Support |
Enrollment |
Via user-initiated |
Via an enrollment |
Via an enrollment |
Via Automated Device Enrollment using a PreStage enrollment |
Via Automated Device Enrollment using a PreStage enrollment and Apple Configurator 2 |
Via Apple |
Inventory |
Submit inventory to |
Extension attributes |
Simple searches |
Advanced searches |
Mobile device reports |
Mass actions |
Device Groups |
Static groups |
Smart groups |
Configuration |
iOS configuration profiles |
Note: You cannot apply profiles that require supervision to devices enrolled using User Enrollment. For more information on the payloads that can be configured for devices enrolled using User Enrollment, see User Enrollment payload list in Apple’s Mobile Device Management Settings. |
Remote Commands5 |
Update inventory |
Lock device |
Clear passcode |
Update passcode lock grace period |
Clear Screen Time Passcode (This command was previously called "Clear Restrictions".) |
Wipe device |
Set Shared iPad User Space (This command was previously called "Set Storage Quota Size") |
Unmanage device |
Wipe institutional data |
Send blank push |
Set wallpaper |
Enable/disable voice or data roaming |
Update iOS version via mass action |
Log out user (Shared iPad only) |
Enable/disable Lost Mode |
Update location |
Enable/disable diagnostic and usage reporting (Shared iPad only) |
Enable/disable app analytics (Shared iPad only) |
Shut down device (Shared iPad only) |
Restart device |
Enable/disable Bluetooth |
Set Activation Lock |
Enable/disable Personal Hotspot |
Manage Jamf Parent |
Remove restrictions set by Jamf Teacher |
Refresh Cellular Plans |
Renew MDM Profile |
Set Time Zone |
Recommend Software Update Version |
Jamf Self Service for iOS |
Jamf Self Service app |
iBeacon region monitoring |
Self Service web clip |
App Distribution |
Managed apps |
Managed distribution for mobile devices |
Managed distribution for users |
In-house apps |
App Store apps |
Book Distribution |
Managed books |
Managed distribution |
Install ePub file |
Install iBooks file (iPad only) |
Install PDF |
Notes:
1. Also applies to iPadOS.
2. A limited subset of inventory information is collected for personal devices. For more information, see Mobile Device Inventory and Criteria Reference.
3. Lock Device and Update Inventory are the only remote commands that can be sent via mass action to personally owned devices.
4. Only applies to devices enrolled using User Enrollment.
5. This table does not account for additional requirements like supervision or enrollment using a PreStage enrollment. For information on specific device requirements for each command, see Remote Commands for Mobile Devices.
6. Devices with iOS 13 or later, or iPadOS 13 or later that were enrolled using User Enrollment; manual installation method only
7. Only managed apps can be distributed to personal devices. App Store apps must be assigned to users (user-based assignment) before distributing them to devices enrolled using User Enrollment. For more information, see User-Assigned Volume Assignments.
8. Compatibility and feature support are based on testing with the latest Apple beta releases.
Management Capabilities for tvOS Devices
The following table provides an overview of the management capabilities available with Jamf Pro for institutionally owned Apple TV devices by tvOS version:
tvOS Version |
11 |
12 |
13 |
14 |
151 |
Enrollment |
Via an enrollment profile and Apple Configurator |
Via an enrollment profile and Apple Configurator 2 |
Inventory |
Submit inventory to Jamf Pro |
Device Groups |
Static groups |
Smart groups |
Configuration |
Mobile device configuration profiles |
Remote Commands |
Update inventory |
Unmanage device |
Wipe device |
Send blank push |
Restart device |
Set Time Zone |
App Distribution |
In-house apps |
App Store apps |
Notes:
1. Compatibility and feature support are based on testing with the latest Apple beta releases.
