Mobile Device History Information
Jamf Pro allows you to view history information for each mobile device, such as logs of deployment and management actions. The following table lists what history information you can view for a mobile device:
Category |
Notes |
Management History |
To cancel a pending management command, click Cancel next to the command. |
Audit Logs |
If your environment uses the Healthcare Listener, "Healthcare Listener" is displayed as the value in the Username column for the remote command that is automatically sent to the mobile device. For more information, see Healthcare Listener. |
User and Location History |
A record of the current information is added to the list whenever changes are made to the User and Location category in the mobile device’s inventory information. |
Apps |
To cancel a pending app installation, click Cancel next to the app. |
Managed eBooks |
To cancel a pending installation, clicking Cancel next to the book. To cancel a failed installation, click Cancel next to the book. |
Note: The management history available for a particular device varies depending on the device ownership type, device type, and iOS version. For more information, see Mobile Device Management Capabilities.
Viewing History Information for a Mobile Device
Log in to Jamf Pro.
Click Devices at the top of the page.
Perform a simple or advanced mobile device search.
Click the mobile device you want to view history for.
If you performed a simple search for an item other than mobile devices, you must click Expandnext to an item to view the mobile devices related to that item.
Click the History tab, and then click the category for the type of history information you want to view.
Related Information
For related information about managing mobile devices, see the following sections in this guide:
Group Management
Learn how to use smart or static groups to manage mobile devices. -
Simple Mobile Device Searches
Learn how to find history information using simple mobile device searches. -
Advanced Mobile Device Searches
Learn how to find history information using advanced mobile device searches.
