Jamf Pro URL
The Jamf Pro URL is the URL that client applications, computers, and mobile devices connect to when communicating with the Jamf Pro server. You can view and configure the Jamf Pro URL in Jamf Pro if you are hosting your own Jamf Pro server. It is recommended that you configure the Jamf Pro URL to include the correct protocol, fully qualified domain name (FQDN), and port of the server.
Important: In general, you should not change the Jamf Pro URL in a production environment with managed computers and mobile devices. If the Jamf Pro URL is incorrect or not specified, client applications, computers, and mobile devices are unable to connect to the server. If you are considering making a change to your Jamf Pro URL, contact Jamf Customer Success.
You can also view or configure the Jamf Pro URL that’s used for enrolling mobile devices with an enrollment profile and Apple’s iPhone Configuration Utility (iPCU).
Note: If your environment is hosted in Jamf Cloud, the Jamf Pro URL setting is managed by Jamf Cloud and is not accessible.
Viewing or Configuring the Jamf Pro URLs
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/84804394/Icon_Settings_Hover.png .
  3. Click Global Management.
  4. Click Jamf Pro URL images/download/thumbnails/84804394/Icon_Jamf_Pro_URL.png .
    The Jamf Pro URLs are displayed on the pane.
  5. To configure the Jamf Pro URLs:
    1. Click Edit.
    2. Enter the new URLs in the fields on the pane.
    3. Click Save.
Related Information
Enrollment Profiles
Find out how to create and download enrollment profiles so you can enroll mobile devices by connecting them to a computer via USB.
