Flushing Logs
Flushing logs reduces the size of the database and can speed up searches. You can flush the following types of logs:
  • Application Usage logs
  • Computer Usage logs
  • Policy logs
  • Jamf Remote logs
  • Screen sharing logs
  • Jamf Imaging logs
  • Computer and mobile device management history
  • Computer inventory reports (computer inventory information from past inventory submissions)
  • Mobile device inventory reports (mobile device inventory information from past inventory submissions)
  • Jamf Pro access logs
  • Change Management logs
  • Event logs
  • User and Location History
  • User Reports
You can schedule log flushing to take place daily, or you can manually flush logs as needed. You can also choose to flush logs that are older than a certain number of days, weeks, or months.
Scheduling Log Flushing
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81932166/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click Log Flushing images/download/thumbnails/81932166/Log_Flushing.png .
  5. Click Edit images/download/thumbnails/81532686/edit.png .
  6. Use the pop-up menus to choose the number of days, weeks, or months after which each type of log should be flushed.
  7. Choose a time of day from the Time to Flush Logs Each Day pop-up menu.
  8. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Manually Flushing Logs
  1. Log in to any of the Jamf Pro web apps.
  5. Click Flush images/download/thumbnails/80748262/trash.png .
  6. Select the checkbox for each type of log you want to flush.
  7. From the Flush Logs Older Than pop-up menu, choose the number of days, weeks, or months after which logs should be flushed.
  8. Click Flush images/download/thumbnails/80748262/trash.png .
A message displays, reporting the success or failure of the flush.
Related Information
For related information, see the following article:
Data and Tables Affected by Log Flushing
Learn about the types of data flushed with each log and the database tables affected.
