Deleting a Mobile Device from Jamf Pro
You can remove a mobile device from your inventory by deleting it from Jamf Pro.
Note: The components installed during enrollment are not removed from the mobile device when it is deleted from Jamf Pro. It is recommended that you unmanage the device before deleting it.
  1. Log in to Jamf Pro.
  3. Click Search Inventory.
  4. Perform a simple or advanced mobile device search.
    For more information, see Simple Mobile Device Searches or Advanced Mobile Device Searches .
  5. Click the mobile device you want to delete.
    If you performed a simple search for mobile device applications, you must click Expand images/download/thumbnails/81936183/Icon_Expand.png next to an item name to view the mobile devices related to that item.
  6. Click Delete images/download/thumbnails/80748262/trash.png , and then click Delete again to confirm.
Related Information
