Simple Computer Searches
A simple computer search functions like a search engine, allowing you to quickly search the items in your inventory for a general range of results.
The following table shows the items that you can search by and the attributes on which you can base each search:
Inventory Item |
Searchable Attributes |
Computers |
Computer name |
Applications |
Application name |
Local User Accounts |
Username |
Application Usage |
Application name |
Fonts |
Font name |
Package Receipts |
Package receipt name |
Plug-ins |
Plug-in name |
Printers |
Printer name |
Services |
Service name |
Software Updates |
Software update name |
Note: Computers and applications are searchable by default. The other items are searchable if Jamf Pro is configured to collect them as inventory.
Search Syntax
This section explains the syntax to use for search functions. In general, searches are not case-sensitive.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. For more information about configuring account preferences, see Jamf Pro User Accounts and Groups.
The following table explains the syntax you can use for search functions:
Search Function |
Usage |
Example |
Return all Results |
Use an asterisk (*) without any other characters or terms, or perform a blank search. |
Perform a search for “*” or leave the search field empty to return all results. |
Perform Wildcard Searches |
Use an asterisk after a search term to return all results with attributes that begin with that term. |
Perform a search for “key*” to return all results with names that begin with “key”. |
Use an asterisk before a search term to return all results with attributes that end with that term. |
Perform a search for “*note” to return all results with names that end with “note”. |
Use an asterisk before and after a search term to return all results that include that term. |
Perform a search for “*ABC*” to return all results that includes “ABC”. |
Include Multiple Search Terms |
Use multiple search terms separated by a comma (,) to return all results that include those search terms. |
Perform a search for “key*, *note” to return all results that begins with “key” and ends with “note”. |
Exclude a Search Term |
Use a hyphen (-) before a search term to exclude results that include the term. |
Perform a search for “ABC*, -*note” to return all results with names that begin with “ABC” except for those that end with “note”. |
Performing a Simple Computer Search
Log in to Jamf Pro.
Click Computers at the top of the page.
Click Search Inventory.
Choose an item from the Search pop-up menu.
Enter one or more search terms in the fields provided.
Press the Enter key.
If you searched for an item other than computers, you can view the computers associated with a result by clicking Expand
next to the result. You can also change the item on which the results are based by choosing an item from the pop-up menu at the top of the page.
Related Information
Computer Inventory Information
Find out how to view and edit inventory information for a computer. -
Computer Inventory Collection Settings
Find out how to configure what inventory information Jamf Pro collects. -
Advanced Computer Searches
Find out how to create an advanced search using detailed criteria. -
Computer Reports
Find out how to export the data in your search results to different file formats. -
Mass Actions for Computers
Find out how to perform actions on the results of a computer search. -
Computer Inventory Display Settings
Find out how to change the attribute fields displayed in the results of a simple computer search.
