Policy Management
When you create a policy, you use a payload-based interface to configure settings for the policy and add tasks to it. For more information on the settings you can configure, see Policy Payload Reference.
After you create a policy, you can view the plan, status, and logs for the policy. You can also flush policy logs.
Note: To run a policy on a computer, the Allow Jamf Pro to perform management tasks checkbox must be selected in the computer inventory information to enable the management account. For more information about the management account, see Computer Enrollment Methods.
Creating a Policy
Log in to Jamf Pro.
Click Computers at the top of the page.
Click Policies.
Click New
Use the General payload to configure basic settings for the policy, including the trigger and execution frequency.
Use the rest of the payloads to configure the tasks you want to perform.
Click the Scope tab and configure the scope of the policy.
(Optional) Click the Self Service tab and make the policy available in Self Service.
Note: On computers with macOS 10.15 or later, if Jamf Pro is not safelisted in the Privacy Preferences Policy Control payload, users are prompted when policies that access data on a network volume are run through Self Service. By default, Jamf Pro is automatically safelisted in the Privacy Preferences Policy Control payload.
(Optional) Click the User Interaction tab and enter messages to display to users or allow users to defer the policy.
Click Save
The policy runs on computers in the scope the next time they check in with Jamf Pro and meet the criteria in the General payload.
Running a Policy
There are two ways to run a policy with a pre-defined trigger. You can run a policy using the following methods:
Wait until the configured trigger event occurs.
Manually trigger the policy using the jamf binary.
To manually trigger the policy using the jamf binary, execute the following command on managed computers:
sudo jamf policy -event <triggerName> -verbose
If the policy has a pre-defined trigger, replace <triggerName> with the appropriate value. The following is a list of pre-defined triggers:
Startup—startup
Login—login
Logout—logout
Network State Change—networkStateChange
Enrollment Complete—enrollmentComplete
Recurring Check-in—None (execute sudo jamf policy -verbose)
If the policy has a custom trigger, replace <triggerName> with the custom trigger name specified in the policy.
Note: A policy with a custom trigger must be run manually using the jamf binary.
Viewing the Plan for a Policy
The plan for a policy includes the following information:
An indicator light that shows whether the policy is enabled.
The execution frequency.
The triggers.
The scope.
The site that the policy belongs to.
A list of actions for the policy .
Log in to Jamf Pro.
Click Policies.
A list of policies and their plans are displayed. -
To view the actions for a policy, click Expand
for the policy.
Viewing the Status of a Policy
For each policy, you can view a pie chart that shows the number of computers for which the policy has completed, failed, and is still remaining.
Log in to Jamf Pro.
Click Policies.
Click Grid View
at the top of the list.
Viewing and Flushing Logs for a Policy
The logs for a policy include a list of computers that have run the policy and the following information for each computer:
The date/time that the policy ran on the computer
The status
The actions logged
Log in to Jamf Pro.
Click Policies.
Click the policy you want to view logs for.
Click Logs.
To view the actions logged for a computer, click Details for the computer.
To hide the information when you are done viewing it, click Hide. -
To flush a policy log for a single computer, click Flush for the computer.
To flush all logs for the policy, click Flush All at the bottom of the pane.
Related Information
Viewing and Flushing Policy Logs for a Computer
Find out how to view and flush policy logs for a single computer. -
Flushing Logs
Find out how to flush all policy logs. -
User Interaction with Policies
Find out how to configure user interaction with policies. -
Items Available to Users in Jamf Self Service for macOS
Find out how to make items available to users in Jamf Self Service for macOS.
