Advanced Computer Searches
Advanced computer searches allow you to use detailed search criteria to search the managed and unmanaged computers in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Criteria Operators
The following table lists operators and examples of how they might be used to qualify values:
Operator
Definition
Example
is
Matches the specified string exactly
The criteria "'Computer Name' is 'Test Computer 6'" includescomputers with the name "Test Computer 6". By contrast, a computer with the name "Test Computer 7" is not included.
is not
Matches values that do not match the specified string exactly
The criteria "'Display Name' is not 'CEO iPad'" includes all devices except those with the exact display name "CEO iPad". By contrast, a device with the display name "'CEO iPad Old'" is not included.
like
Matches value that contain the specified string
The criteria "'Computer Name' like 'AP Science Mac'" includes computers with names such as "AP Science Mac 1", "AP Science Mac 2", and "AP Science Mac 3".
not like
Matches values that do not contain the specified string
The criteria "'Display Name' not like 'Staff'" includes devices with display names such as "Student A", "Student B", and "Smith Personal iPhone".
matches regex
Matches values that match the specified regular expression (regex). For more information on regex, see the Using Regex with Smart Groups and Advanced Searches article.
The criteria "'Computer Name' matches regex '^LAB-.*$s'" includes computers with names such as "LAB-ART-101", "LAB-CS-101", and "LAB-CS-102".
does not match regex
Matches values that do not match the specified regular expression (regex). For more information on regex, see the Using Regex with Smart Groups and Advanced Searches article.
The criteria "'Display Name' does not match regex '^HS'" includes devices with display names such as "iPad HS loaner" and " 11 HS iPad".
And/Or Groupings
If you have multiple criteria, you can use "and/or" groupings to define the relationships between them and create logic that includes the devices you want in your advanced search. The following groupings are available when multiple criteria are used:
  • and—Only devices that fulfill all related criteria will be included in membership.
  • or—Devices that fulfill any of the related criteria will be included in membership.
If more complex logic is necessary to define the relationships between your criteria, you can use the parenthesis pop-ups to group criteria together.
Creating an Advanced Computer Search
  1. Log in to Jamf Pro.
  3. Click Search Inventory.
  4. Click New images/download/thumbnails/85395582/Icon_New_Button.png .
    1. Click Add images/download/thumbnails/85395582/Icon_Add_Button.png .
      Note: Only your 30 most frequently used criteria are listed. To display additional criteria, click Show Advanced Criteria.
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/85395582/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menus to specify the relationships between criteria.
    images/download/attachments/85395582/Computer_New_Advanced_Computer_Search.png
  10. Click Save images/download/thumbnails/81531754/floppy-disk.png .
  11. To view the search results, click View images/download/thumbnails/85395582/preview-content.png .
    The results of a saved search are updated each time you view the membership.
  12. (Optional) To export the search results, click Export and follow the on-screen instructions.
Related Information
Computer Inventory Information
Find out how to view and edit inventory information for a computer.
