Startup Script
The Startup Script settings in Jamf Pro allow you to create a startup script on computers and use it to perform the following actions at startup:
Log Computer Usage information (date/time of startup).
Check for policies triggered at startup.
Ensure SSH (Remote Login) is enabled on computers.
Configuring the Startup Script
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Computer Management.
In the “Computer Management–Management Framework” section, click Check-In
Click Edit
Configure the startup script settings using the checkboxes on the pane.
Click Save
Related Information
Computer Usage
Find out how to view Computer Usage information logged at startup. -
Policy Management
You can create policies that are triggered at startup. -
Components Installed on Managed Computers
Find out where the startup script is stored on computers.
