Network Segments
A network segment is a range of IP addresses that can be used to group computers and mobile devices based on their network location. Network segments can be class B or class C subnets, or any IP range therein.
Adding network segments to Jamf Pro allows you to do the following:
  • Ensure that computers and mobile devices use the closest distribution point by default.
  • Ensure that computers use the closest NetBoot server by default.
  • Specify a software update server for computers to use by default.
  • Automatically update the building and department to which computers and mobile devices belong.
  • Base the scope of remote management tasks on network segments.
If a computer belongs to multiple network segments, Jamf Pro uses and updates both IP addresses to distribute content.
Adding a Network Segment
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/82683965/Icon_Settings_Hover.png .
  3. Click Network Organization.
  4. Click Network Segments images/download/thumbnails/82683965/Network_Segments.png .
  5. Click New images/download/thumbnails/82683965/Icon_New_Button.png .
  6. Configure the network segment using the settings on the pane.
  7. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Related Information
For related information, see the following article:
Collecting the IP Address and Reported IP Address in Jamf Pro
Find out about how IP addresses are collected and network segments are calculated.
