Mobile Device Management Capabilities
Jamf Pro can be used to enroll and manage the following devices:
  • iOS devices
  • iPadOS devices
  • tvOS devices
  • Personally owned iOS devices
The management capabilities available for a particular device vary depending on the device ownership type, device type, and OS version.
This section includes information for OS versions that meet the minimum system requirements for managed mobile devices in Jamf Pro. For information on these requirements, see Jamf Pro System Requirements in the Jamf Pro Release Notes.
Note: This section provides an overview of mobile device management capabilities by OS version and does not account for additional feature-specific requirements. For information on feature-specific requirements, see the documentation for that feature.
Management Capabilities for Mobile Devices
The following table provides an overview of the management capabilities available with Jamf Pro for iPad, iPhone, and iPod touch devices by iOS version:
iOS Version
11
12
131
141
Personally Owned iOS Device Support
Enrollment
Via user-initiated
enrollment
images/download/thumbnails/81950267/checkmark.png
Via an enrollment
profile and Apple
Configurator
Via an enrollment
profile and Apple
Configurator 2
Via Automated Device Enrollment using a PreStage enrollment
Via Automated Device Enrollment using a PreStage enrollment and Apple Configurator 2
Via Apple
Configurator 2
using an enrollment URL
Inventory
Submit inventory to
Jamf Pro
images/download/thumbnails/81950267/checkmark0.png 2
Extension attributes
Simple searches
Advanced searches
Mobile device reports
Mass actions
images/download/thumbnails/81950267/checkmark0.png 3
Device Groups
Static groups
images/download/thumbnails/81950267/checkmark0.png 4
Smart groups
Configuration
iOS configuration profiles
Note: You cannot apply profiles that require supervision to devices enrolled using User Enrollment. For more information on the payloads that can be configured for devices enrolled using User Enrollment, see User Enrollment payload list in Apple’s Mobile Device Management Settings.
Remote Commands5
Update inventory
Lock device
Clear passcode
Update passcode lock grace period
Clear Screen Time Passcode
(This command was previously called "Clear Restrictions".)
Wipe device
Set Shared iPad User Space
(This command was previously called "Set Storage Quota Size")
Unmanage device
Wipe institutional data
Send blank push
Set wallpaper
Enable/disable voice or data roaming
Update iOS version via mass action
Log out user (Shared iPad only)
Enable/disable Lost Mode
Update location
Enable/disable diagnostic and usage reporting (Shared iPad only)
Enable/disable app analytics (Shared iPad only)
Shut down device (Shared iPad only)
Restart device
Enable/disable Bluetooth
Set Activation Lock
Enable/disable Personal Hotspot
Manage Jamf Parent
Remove restrictions set by Jamf Teacher
Refresh Cellular Plans
Renew MDM Profile
Set Time Zone
Jamf Self Service for iOS
Jamf Self Service app
images/download/thumbnails/81950267/checkmark0.png 6
iBeacon region monitoring
Self Service web clip
App Distribution
Managed apps
Managed distribution for mobile devices
Managed distribution for users
In-house apps
images/download/thumbnails/81950267/checkmark0.png 7
App Store apps
Book Distribution
Managed books
Install ePub file
Install iBooks file (iPad only)
Install PDF
Notes:
1. Also applies to iPadOS.
2. A limited subset of inventory information is collected for personal devices. For more information, see Mobile Device Inventory Information Reference.
3. Lock Device and Update Inventory are the only remote commands that can be sent via mass action to personally owned devices.
4. Only applies to devices enrolled using User Enrollment.
5. This table does not account for additional requirements like supervision or enrollment using a PreStage enrollment. For information on specific device requirements for each command, see Remote Commands for Mobile Devices.
6. Devices with iOS 13 or later, or iPadOS 13 or later that were enrolled using User Enrollment; manual installation method only
7. Only managed apps can be distributed to personal devices. App Store apps must be assigned to users (user-based assignment) before distributing them to devices enrolled using User Enrollment. For more information, see User-Assigned Volume Assignments.
Management Capabilities for tvOS Devices
The following table provides an overview of the management capabilities available with Jamf Pro for institutionally owned Apple TV devices by tvOS version:
tvOS Version
11
12
13
14
Enrollment
Via an enrollment profile and Apple Configurator
Via an enrollment profile and Apple Configurator 2
Inventory
Submit inventory to Jamf Pro
Device Groups
Static groups
Smart groups
Configuration
Mobile device configuration profiles
Remote Commands
Update inventory
Unmanage device
Wipe device
Send blank push
Restart device
Set Time Zone
App Distribution
In-house apps
App Store apps
