Login and Logout Hooks
The Login/Logout Hooks settings in Jamf Pro allow you to create login and logout hooks on computers and use them to perform the following actions:
Log Computer Usage information (username and date/time) at login and logout.
Check for policies triggered at login or logout.
Hide the Restore partition at login.
Warning: Creating login and logout hooks with Jamf Pro can disable existing login and logout hooks.
Configuring Login and Logout Hooks
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Computer Management.
In the “Computer Management–Management Framework” section, click Check-In
Click Edit
Configure the login/logout hooks settings using the checkboxes on the pane.
Click Save
Related Information
Computer Usage
Find out how to view Computer Usage information logged at login and logout. -
Policy Management
You can create policies that are triggered at login or logout. -
Components Installed on Managed Computers
Find out where login/logout hooks are stored on computers.
