Change Management
Change Management allows you to track the changes that happen in Jamf Pro, such as the creation of a Jamf Pro user account. The Change Management settings in Jamf Pro allow you to log those changes to a log file (JAMFChangeManagement.log) on the Jamf Pro host server and log the changes to a syslog server.
The Change Management logs can also be viewed in Jamf Pro. The information displayed includes:
  • Date/time the change took place
  • Username of the administrator who made the change
  • Object type (such as a Jamf Pro user account)
  • Object name (such as the username of a Jamf Pro user account)
  • Action (such as “Created”)
  • Details about the change
In addition, you can view the changes to a specific object in that object’s history.
Note: The option to log changes to a log file or a syslog server is only available for on-premise environments. If your environment is hosted in Jamf Cloud, changes are automatically displayed in the Change Management settings and cannot be exported.
General Requirements
To log changes to a log file, the account used to run Tomcat must have write permissions for the directory where the JAMFChangeManagement.log file is located.
Configuring the Change Management Settings for On-Premise Environments
The option to configure the Change Management settings is only available for on-premise environments. If your environment is hosted in Jamf Cloud, changes are automatically displayed in the Change Management settings.
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81932158/Icon_Settings_Hover.png .
  3. Click System Settings.
  4. Click Change Management images/download/thumbnails/81932158/Change_Management.png .
  5. Click Edit images/download/thumbnails/81532686/edit.png .
  6. Configure the settings on the pane.
  7. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Viewing Change Management Logs in Jamf Pro
    The Change Management logs are displayed on the pane.
  5. Do one of the following:
    • To view the object associated with a change, click the object in the Object Name column.
    • To view details about the change, click Details in the Details column.
Related Information
For related information, see the following section:
Jamf Pro Objects
Find out how to view the history of a Jamf Pro object.
