Apple Configurator Enrollment Settings
The Apple Configurator Enrollment settings allow you to enroll mobile devices with Jamf Pro using Apple Configurator 2 and an enrollment URL. This involves enabling Apple Configurator enrollment in Jamf Pro, and then connecting devices to a computer via USB to enroll them using Apple Configurator 2 and an enrollment URL.
You can enable one or both of the following types of Apple Configurator enrollment URL:
Static URL – Using a static URL allows you to manually provide the URL to the person that operates the Apple Configurator workstation in the way that best fits your environment. The static URL cannot expire and does not allow you to enroll devices into sites as a part of the enrollment process.
The static enrollment URL for Jamf Pro is the URL for the Jamf Pro server followed by
“/configuratorenroll”. For example:-
https://instancename.jamfcloud.com (hosted in Jamf Cloud)
https://jamf.instancename.com:8443 (hosted on-premise)
Dynamic URL – Using a dynamic URL allows you to view a randomly generated enrollment URL in Jamf Pro or send that URL to the person that operates the Apple Configurator workstation via an enrollment invitation, allowing for a more secure enrollment experience. When you view or send a dynamic URL via an enrollment invitation, you can set the expiration date for the URL and choose a site to add devices to during enrollment.
General Requirements
Apple Configurator enrollment only applies to mobile devices with iOS 9 or later. In addition, you need Apple Configurator 2.0 or 2.1.
Enabling Apple Configurator Enrollment via Static URL
Before you can enroll mobile devices using Apple Configurator and a static URL, you must enable Apple Configurator enrollment in Jamf Pro.
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Mobile Device Management.
Click Apple Configurator Enrollment
Click the Enrollment tab, and then click Edit.
Select Enable Apple Configurator Enrollment via Static URL.
Click Save
You can now use the static URL with your Apple Configurator workstation.
Enabling Apple Configurator Enrollment via Dynamic URL
Before you can enroll mobile devices using Apple Configurator and a dynamic URL, you must enable Apple Configurator enrollment in Jamf Pro.
Log in to Jamf Pro.
Select Enable Apple Configurator Enrollment via Dynamic URL .
Click Save
Dynamic URLs can now be viewed in Jamf Pro or sent to the person that operates the Apple Configurator workstation via an enrollment invitation.
Viewing or Sending a Dynamic Apple Configurator Enrollment URL via a Mobile Device Enrollment Invitation
You can view the dynamic Apple Configurator enrollment URL or send an email or SMS invitation that contains the URL from Jamf Pro to the person that operates the Apple Configurator workstation. The enrollment URL is used with Apple Configurator to enroll mobile devices with Jamf Pro.
Before you configure the invitation, make sure you have the email address or phone number of the person you want to send the invitation to.
Log in to Jamf Pro.
Click Devices at the top of the page.
Click Enrollment Invitations.
Click New
Select Apple Configurator Enrollment as the enrollment method.
Follow the onscreen instructions to view or send the enrollment invitation.
If you chose to view the enrollment URL, it is displayed in Jamf Pro. If you chose to send the enrollment URL, an enrollment invitation containing the dynamic URL is sent to the email addresses or phone numbers you specified.
You can view the status of the enrollment invitation in the list of invitations.
Viewing Mobile Device Enrollment Invitation Usage
You can view a list of mobile devices that were enrolled with a specific enrollment invitation.
Log in to Jamf Pro.
Click the enrollment invitation you want to view usage for.
Click View Enrolled Mobile Devices
A list of mobile devices enrolled with the invitation is displayed.
Related Information
Supervision Identities
Find out how to create, upload, and download a supervision identity for use with Apple Configurator 2. -
Components Installed on Mobile Devices
Learn about the components installed on mobile devices during enrollment.
For related information, see the following technical paper:
Deploying iOS and tvOS Devices Using Apple Configurator 2 and Jamf Pro
Get step-by-step instructions on how to deploy iOS devices using Apple Configurator 2 and an enrollment URL.
