Jamf Pro System Requirements
Levels of Compatibility
The following table provides descriptions of the levels of compatibility for Jamf Pro testing and product issue support:
Compatibility Level
Testing
Product Issue Support
Recommended
Full compatibility
Jamf targets development and testing resources to configurations at this level.
Full
Jamf is committed to fixing product issues that arise at this level.
Minimum Supported
High compatibility
Most configurations at this level were previously recommended and are likely to work.
Partial
Jamf will attempt to fix product issues that arise at this level.
Computer and Mobile Device Management Only
Untested
Limited compatibility
Management is not actively removed, and computers and mobile devices should continue to be managed after upgrading Jamf Pro. Some features may not be available or may no longer work.
None
Jamf will not fix product issues that arise at this level.
Support Removed
No compatibility
Management capabilities are actively removed, and most computers and mobile devices can no longer be managed after upgrading Jamf Pro.
None
Jamf Pro compatibility with Apple operating system (OS) releases for computer and mobile device management is generally based on an N-3 support policy. This means that Jamf Pro will support the current major version (“N”) and the three previous major versions (“-3”) within either the Recommended or Minimum Supported compatibility levels. When a new Apple OS version is made available and added to Recommended, the oldest release will be moved from the Minimum Supported to Untested level.
The following table lists Apple OS compatibility requirements for managed computers and mobile devices:
macOS1
iOS
iPadOS
tvOS
Recommended
macOS 11.x
iOS 14.x
iPadOS 14.x
tvOS 14.x
macOS 10.15.x
Minimum Supported
macOS 10.14.x
iOS 13.x
iPadOS 13.x
tvOS 13.x
macOS 10.13.x
iOS 12.x
tvOS 12.x
iOS 11.x
tvOS 11.x
Untested 2, 3
macOS 10.12.x
iOS 10.x3
tvOS 10.x
macOS 10.11.x
iOS 9.x
macOS 10.10.x
iOS 8.x
Support Removed
macOS 10.9.x and earlier
iOS 7.x and earlier
tvOS 9.x and earlier
1. Also indicates macOS versions required to run Composer on Mac computers.
2. It is strongly recommended that you test management workflows in a non-production environment prior to upgrading Jamf Pro.
3. Legacy versions of the Jamf management framework and Jamf Self Service will be installed on devices at this level. For more information, see the following:
Web Browsers
The following table lists the browser requirements for enrollment and access to web applications:
macOS
iOS
Windows
Linux
Recommended
Safari
Safari
Chrome
Minimum Supported
Chrome
Firefox
Chrome
Firefox
Microsoft Edge
Internet Explorer 11
Jamf Pro Server Environment
The following table lists the server and related services requirements for Jamf Pro on-premise environments and the Jamf Pro installers1:
Server OS2
Database Configuration
Java
Recommended
  • Windows Server 2019
  • Ubuntu Server 20.04 LTS
  • Red Hat Enterprise Linux 7.x
  • macOS 10.155
  • MySQL 8.0 – InnoDB3,4
  • Amazon Aurora (MySQL 5.7 compatible)
  • MySQL 5.7.8 or later – InnoDB3
OpenJDK 11
Minimum Supported
  • Windows Server 2016
  • Windows Server 2012 R2
  • Ubuntu Server 18.04 LTS
  • macOS 10.145
  • MySQL 5.7.8 – InnoDB3
  • MySQL 5.7.8 on Amazon RDS – InnoDB
Oracle Java 11
1. For a list of the Tomcat versions installed with each release, see the Apache Tomcat Versions Installed by the Jamf Pro Installer Knowledge Base article.
2. All compatible operating systems are 64-bit only.
3. The Jamf Pro database does not support MySQL clustering.
4. Hosting Jamf Pro databases with MySQL 8.0 on Amazon RDS is not currently supported.
5. macOS is not recommended for clustered environments.
