Testing Attribute Mappings
You can test the following attribute mappings:
User mappings
User group mappings
User group membership mappings
If Jamf Pro returns the appropriate information, the attributes are mapped correctly.
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click System Settings.
Click Cloud Identity Providers
Click the instance name you want to test.
Click Test
Click the appropriate tab and enter information in the fields provided.
Click Test again.
Related Information
Configuring Cloud Identity Provider Attribute Mappings Using Jamf Pro API
Learn how to configure attribute mappings for your cloud identity provider instance using Jamf Pro API.
