Jamf Self Service for macOS Branding Settings
You can customize how Self Service displays to your end users by configuring the following settings:
Icon—The branding icon displays on the Self Service Login page, in the branding header in Self Service, and as the Self Service icon in the Finder and the Dock. You can customize the branding icon by replacing the default Self Service logo with your organization's logo or another icon of your choice. It is recommended that you use a GIF or PNG file that is 180x180 pixels.
Branding Header—The branding header displays across the top of Self Service. You can customize the branding header image by replacing the default image with an image of your choosing. It is recommended that you use a GIF or PNG file that is 1000x335 pixels.
Branding Name—The branding name displays on the Self Service Login page and in the branding header in Self Service. By default, "Self Service" is displayed as the branding name. You can customize the branding name by modifying the Main Header and Secondary Header text fields.
Application Name—The application name displays in the Finder, the Dock, and in the app title bar and menu. By default, "Self Service" is displayed as the application name. You can customize the application name by modifying the Application Name text field.
Configuring the Branding Settings
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Self Service.
Click Branding
Click the default macOS branding configuration.
Click Edit
Configure the settings on the pane.
Once a change is made, it automatically appears in the Branding Preview field at the top of the page. -
Click Save
The branding configuration is displayed in Self Service the next time computers check in with Jamf Pro.
