Jamf Protect Integration with Jamf Pro
Jamf Protect is an enterprise endpoint security solution for Mac computers. With Jamf Protect, you can create custom detections that protect computers with real-time monitoring for suspicious and unwanted activities, while measuring computers against the Center for Internet Security (CIS) benchmarks with security insights. Jamf Protect runs without using kernel extensions to support continuous macOS updates and preserve the Apple user experience.
Integrating Jamf Protect allows you to do the following from Jamf Pro:
Enable automatic package deployment.
Download the Jamf Protect package.
Sync Jamf Protect plan configuration profiles.
To integrate Jamf Pro with your Jamf Protect tenant, you must do the following:
Create an API Client in Jamf Protect—Create an API Client to generate configuration and endpoint information required by Jamf Pro.
Register your Jamf Protect tenant in Jamf Pro—Register your Jamf Protect tenant to establish a secure connection between Jamf Pro and Jamf Protect.
Registering your Jamf Protect Tenant in Jamf Pro
Requirements
Cloud Connection Services enabled
For instructions, see Cloud Services Connection. -
An API Client created in Jamf Protect
For instructions, see the API Overview section in the Jamf Protect Administrator's Guide. -
The following Jamf Pro user account privileges:
Category
Privilege
Jamf Pro Server Settings
Jamf Protect (Read and Update)
Cloud Services Connection (Read)
Jamf Pro Server Actions
Read and Download Jamf Application Assets
Procedure
Log in to Jamf Pro.
In the top-right corner of the page, click Settings
Click Jamf Applications.
Click Jamf Protect
Click Begin Registration.
Enter your Jamf Protect API endpoint in the Jamf Protect API URL field.
Enter your API Client configuration information in the Client ID and Password fields.
Click Register.
Your Jamf Protect tenant is integrated with your Jamf Pro instance and a package download and list of plans should display.
Jamf Protect Plans in Jamf Pro
If you have a Jamf Protect subscription and registered your Jamf Protect tenant with Jamf Pro, plans from your Jamf Protect tenant are available as computer configuration profiles in Jamf Pro. You can configure the scope of plan configuration profiles to deploy them to target computers.
Keep the following in mind when configuring scope for plan configuration profiles:
If you select the Automatically deploy the Jamf Protect PKG with plans checkbox in the Jamf Protect Deployment section, the Jamf Protect PKG is automatically deployed to computers in the scope of a plan that have not yet installed the Jamf Protect PKG.
If you delete plan configuration profiles from Jamf Protect, the plans will re-appear without a scope the next time Jamf Pro syncs with Jamf Protect (every six hours).
You cannot edit the settings in a Jamf Protect plan from Jamf Pro. To edit a plan, navigate to the plan in your Jamf Protect tenant. Changes to a plan on computers are applied the next time the computer checks in with Jamf Protect.
If the Jamf Protect PKG is deployed without a plan configuration profile, computers will not check in with the Jamf Protect Cloud and the agent will not successfully monitor for threats. Configuring scope for your plans before deploying the Jamf Protect PKG is recommended.
To help you find plan configuration profiles synced from Jamf Protect on the computer configuration profiles pane, "Jamf Protect Configuration" is appended to each profile name that is synced.
Important: Plans that are manually uploaded to Jamf Pro will not appear in the Jamf Protect section of Jamf Pro. Deleting these plans configuration profiles and re-applying their scope to plans synced from Jamf Protect is recommended. This ensures you do not have duplicate versions of a plan in Jamf Pro and that scope is accurately configured. For more information about switching from manually uploaded plans to plans that are synced between Jamf Pro and Jamf Protect, see the Switching from Manually Uploaded Jamf Protect Plans to Synced Plans in Jamf Pro Knowledge Base article.
Configuring Scope for Jamf Protect Plans
You can configure the scope of available plan configuration profiles to deploy them to target computers.
Requirements
A Jamf Protect subscription
One or more plans in Jamf Protect
For more information, see the Creating a Plan section in the Jamf Protect Administrator's Guide. -
Registration of your Jamf Protect tenant in Jamf Pro
Procedure
Log in to Jamf Pro.
Click Jamf Protect
In the Jamf Protect Plans table, click on the plan configuration profile you want to configure in the Profile column.
Note: You can click Sync to manually check Jamf Protect for plan updates. Jamf Pro automatically syncs with Jamf Protect every six hours.
Click Edit.
Click the Scope tab.
Configure the scope of your plan configuration profile.
Click Save.
The plan configuration profile is distributed to target computers the next time they check in with Jamf Pro, and the scope also displays in the Scope column on the Jamf Protect page in Jamf Pro. If you selected the Automatically deploy the Jamf Protect PKG with plans checkbox in the Jamf Protect Deployment section, the Jamf Protect PKG is automatically deployed to computers in the scope that have not yet installed the Jamf Protect PKG.
Related Information
For related information about deploying Jamf Protect using Jamf Pro, see the Deploying Jamf Platform Products Using Jamf Pro to Connect, Manage, and Protect Mac Computers technical paper.
For related information about Jamf Protect, see the the following sections in the Jamf Protect Administrator's Guide:
Plans
Learn more about security settings in Jamf Protect plans. -
Remediating Detections with Jamf Pro
Learn how to remediate threats found by Jamf Protect with Jamf Pro.
