Advanced User Searches
Advanced user searches allow you to use detailed search criteria to search for users in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced User Search
  1. Log in to Jamf Pro.
  2. Click Users at the top of the page.
  3. Click Search Users.
  4. Click New images/download/thumbnails/81936204/Icon_New_Button.png .
    1. Click Add images/download/thumbnails/81936204/Icon_Add_Button.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/81936204/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menus to specify the relationships between criteria.
    images/download/attachments/81936204/Users_search_.png
    Note: Some criteria cannot be viewed in advanced search results in Jamf Pro. These criteria can be selected for export from the Export Only pane.
  10. Click Save images/download/thumbnails/81531754/floppy-disk.png .
  11. To view the search results, click View images/download/thumbnails/81936204/preview-content.png .
    The results of a saved search are updated each time user information is modified and users meet or fail to meet the specified search criteria.
  12. (Optional) To export the search results, click Export and follow the on-screen instructions.
Related Information
User Inventory Information
Find out how to view and edit inventory information for a user.
