User Enrollment for Personally Owned Mobile Devices
You can allow users to enroll personally owned mobile devices by having them log in to an enrollment portal where they are prompted to install the MDM profile and certificates.
Providing an Enrollment URL to Users
You can provide the enrollment URL to users in the way that best fits your environment.
Requirements
To allow personally owned mobile devices to be enrolled with user-initiated enrollment, you need:
Note: For mobile devices with iOS 10.3 or later, Apple has enabled an important security enhancement that requires untrusted root certificates installed manually on unsupervised iOS devices to be manually trusted in Certificate Trust Settings during user-initiated enrollment, or installation of the MDM profile will fail. For more information, see the Changes in User-Initiated Enrollment with Untrusted Certificate Authority (CA) Signed SSL Certificates in iOS 10.3 and Later Knowledge Base article.
Procedure
To direct users to the enrollment portal, you need to provide them with the enrollment URL. The enrollment URL is the full URL for the Jamf Pro server followed by “/enroll”. For example:
  • https://instancename.jamfcloud.com/enroll (hosted in Jamf Cloud)
  • https://jamf.instancename.com:8443/enroll (hosted on-premise)
Note: Users must use Safari to access the enrollment URL.
Users can log in to the enrollment portal using an LDAP directory account or a Jamf Pro user account. When a user logs in with an LDAP directory account, user and location information is submitted to Jamf Pro during enrollment. When a user logs in with a Jamf Pro user account, it allows an LDAP user to be assigned to the mobile device.
Related Information
For related information, see the following sections in Apple's Mobile Device Management Settings:
For related information, see the following technical paper:
Building a BYOD Program with User Enrollment and Jamf Pro
Get step-by-step instructions on how to enroll personally owned mobile devices using User Enrollment.
