Computer Inventory Information Reference
This section lists the inventory attributes you can view for a computer. Inventory attributes with a minimum macOS version requirement are noted in the Jamf Pro interface. Some attributes are editable.
The following categories of inventory information are only displayed if the Computer Inventory Collection settings are configured to collect them:
  • Local User Accounts
    For more information, see "Local User Accounts Category" below.
  • Printers
  • Active services
  • Last backup date/time for managed mobile devices that are synced to computers
  • User and location from an LDAP directory service (only available if an LDAP server is set up in Jamf Pro)
  • Package receipts
  • Available software updates
  • Application usage information
  • Fonts
  • Plug-ins
  • iBeacon regions
General Category
The following table lists the General category inventory attributes that you can view for a computer:
Inventory Attribute
Notes
Computer Name
Site
Last Inventory Update
Last Check-in
IP Address
To learn how these inventory attributes are collected and how you can manually retrieve the reported IP address, see the Collecting the IP Address and Reported IP Address in Jamf Pro Knowledge Base article.
Reported IP Address
jamf binary Version
Platform
Managed
Supervised
Enrollment Method
Last Enrollment
MDM Capability
Enrolled via Automated Device Enrollment
Displays whether a computer was enrolled via Automated Device Enrollment.
User Approved MDM
Displays the status of User Approved MDM enrollment. For information about User Approved MDM and Jamf Pro, see the Managing User Approved MDM with Jamf Pro Knowledge Base article.
Jamf Pro Computer ID
Asset Tag
Bar Code 1
Bar Code 2
Bluetooth Low Energy Capability
Logged in to the App Store
This value reports as “Active” when a user-level configuration profile is installed from Self Service using MDM-enabled credentials.
Management Account Username
Management Account Password
Hardware Category
The Hardware category allows you to view the following information for a computer:
  • Make
  • Model
  • Model Identifier
  • UDID
  • Serial Number
  • Processor Speed
  • Number of Processors
  • Number of Cores
  • Processor Type
  • Architecture Type
  • Bus Speed
  • Cache Size
  • Primary MAC Address
  • Primary Network Adapter Type
  • Secondary MAC Address
  • Secondary Network Adapter Type
  • Total RAM
    Note: Capacity is reported using the decimal system (base 10), which calculates 1GB as 1 billion bytes.
  • Available RAM Slots
  • Battery Capacity
  • SMC Version
  • NIC Speed
  • Optical Drive
  • Boot ROM
Operating System Category
The Operating System category allows you to view the following information for a computer:
  • Operating System
  • Operating System Version
  • Operating System Build
  • Active Directory Status
  • Master Password Set
  • FileVault Users
  • Service Pack
User and Location Category
All User and Location category inventory attributes are editable and can be populated automatically by assigning a user to a computer. For more information, see User Assignments. The User and Location category allows you to view the following information for a computer:
  • Username
  • Full Name
  • Email Address
  • Position
  • Department
  • Building
  • Room
Notes:
  • To collect User and Location information for computers, the Collect User and Location Information from LDAP setting must be enabled in the Computer Inventory Collection settings. For more information, see Computer Inventory Collection Settings.
  • If the computer is re-enrolled via a PreStage enrollment, there are settings that can affect the user and location information for that computer. For more information, see Computer PreStage Enrollments and Re-enrollment Settings.
Security Category
The Security category allows you to view the following information for a computer:
  • System Integrity Protection
  • Gatekeeper
  • XProtect Definitions Version
  • Disable Automatic Login
  • Remote Desktop Enabled
  • Secure Boot Level
    Note: This attribute displays whether the computer allows or disallows booting from external media. It is only collected on compatible computers with macOS 10.15 or later. For information on compatibility, see About Secure Boot from Apple's support website.
  • Bootstrap Token Allowed (macOS 11 or later)
For more information about the reporting capabilities for some attributes in the Security category, see the Jamf Pro Reporting Capabilities for Apple's macOS Security Features Knowledge Base article.
Purchasing Category
You can look up and populate purchasing information from Apple’s Global Service Exchange (GSX) if you have a GSX connection set up in Jamf Pro. For more information, see GSX Connection. The Purchasing category allows you to view the following information for a computer:
  • Purchased or Leased
  • PO Number
  • PO Date
  • Vendor
  • Warranty Expiration
  • AppleCare ID
  • Lease Expiration
  • Purchase Price
  • Life Expectancy
  • Purchasing Account
  • Purchasing Contact
Extension Attributes Category
This category displays a list of custom data fields collected using extension attributes.
Note: Extension attributes are displayed in computer inventory information in the category in which they are configured to display.
Storage Category
The Storage category allows you to view the following information for a computer:
  • Model
  • Revision
  • Serial Number
  • Drive Capacity
  • S.M.A.R.T. Status
  • Number of Partitions
    Note: The value for the FileVault 2 State of a partition will be reported as “Unknown” if inventory was not updated since the last Jamf Pro upgrade or if Jamf Pro is unable to detect encryption status due to an error.
Disk Encryption Category
This category displays disk encryption information for partitions on a computer. These are the inventory attributes that you can view for each partition of a computer:
Inventory Attribute
Notes
Name
FileVault 2 Partition Encryption State
This value will be reported as “Unknown” if inventory has not been updated since the last Jamf Pro upgrade or if Jamf Pro is unable to detect encryption status due to an error.
Personal Recovery Key Validation
Displays whether the personal (also known as "individual") recovery key on a computer matches the personal recovery key escrowed for that computer in Jamf Pro. This value will be reported as “Unknown” when any of the following conditions are met:
  • macOS version is 10.8 or earlier
  • There is no recovery key in Jamf Pro to validate against
  • Inventory has not been updated since the last Jamf Pro upgrade
To view the recovery key, click Show Key.
Device Recovery Key
Disk Encryption Configuration
Displays the name of the disk encryption configuration if the computer is encrypted via policy. If the computer is encrypted via configuration profile or locally on the computer, this field is left blank.
FileVault 2 Enabled Users
This category displays a list of local user accounts and information about them. You can access commands to remotely unlock a local user account, or remotely remove a local or mobile user account by clicking Manage for a user. For more information, see Remote Commands for Computers.
This information is only displayed if the Computer Inventory Collection settings are configured to collect it. For more information, see Computer Inventory Collection Settings. The following table lists the Local User Accounts category inventory attributes that you can view for a computer:
Inventory Attribute
Notes
UID
Username
Password Type
Only displayed if Jamf Pro can identify the user account type (e.g., “Local", “LDAP", or "Mobile LDAP")
Requires macOS 10.10 or later
Minimum Passcode Length
Maximum Passcode Age
Minimum Number of Complex Characters
Password History
Full Name
Admin
Home Directory
Legacy FileVault Enabled
FileVault 2 Enabled
User Azure Active Directory ID
Unique identifier within Microsoft Azure for users that registered their computers with Azure AD. If the user registers many local accounts or multiple computers, their User Azure Active Directory ID is always the same.
Computer Azure Active Directory ID
Unique identifier within Microsoft Azure for the computer local account. The Computer Azure Active Directory ID is unique across each computer and each local user account. Every time a user registers a computer with Azure AD that local account will be given a unique identifier.
Conditional Access Inventory State (previously named "Azure Active Directory ID")
Displays one of the following values when the macOS Intune Integration is enabled:
  • "Activated"—Computer is registered with Azure AD and regularly checks in with Jamf Pro.
  • "Unresponsive"—Computer has not checked in with Jamf Pro in the last 24 hours using the standard Jamf Pro check-in process, or the computer has not checked in with Microsoft Intune in the last 24 hours. Unresponsive devices are marked "non-compliant" after the validity period passes. (The validity period is specified in the "Compliance status validity period (days)" setting in Microsoft Intune. Default is 30 days.)
  • "Deactivated"—Computer is no longer registered with Azure AD
Attachments Category
You can upload and delete attachments to the inventory record using this category. To upload an attachment, click Upload. To delete an attachment, click Delete.
Content Caching Category
The Content Caching category is only collected for computers with macOS 10.15.4 or later. For more information on content caching reporting capabilities, see Apple's documentation.
The Content Caching category allows you to view the following information for a computer:
  • Activated
  • Active
  • Actual Cache Used
  • Alerts
  • Cache Details
  • Cache Free
  • Cache Limit
  • Cache Status
  • Cache Used
  • Data Migration Completed
  • Data Migration Error
  • Data Migration Progress
  • Max Cache Pressure in Last Hour
  • Parents
  • Personal Cache Free
  • Personal Cache Limit
  • Personal Cache Used
  • Port
  • Public Address
  • Registration Error
  • Registration Response Code
  • Registration Started
  • Registration Status
  • Restricted Media
  • Server GUID
  • Startup Status
  • Tetherator Status
  • Total Bytes are Since
  • Total Bytes Dropped
  • Total Bytes Imported
  • Total Bytes Returned to Children
  • Total Bytes Returned to Clients
  • Total Bytes Returned to Peers
  • Total Bytes Returned from Origin
  • Total Bytes Returned from Parents
  • Total Bytes Returned from Peers
Related Information
Find out what information Jamf Pro collects via MDM Commands.
