Managed Content in Jamf Pro
Managing content using Jamf Pro allows you to have more control over the distribution and removal of apps and books, as well as the backup of data and options for updating the content.
Managed Apps
There are two factors that determine whether an app can be managed by Jamf Pro:
  • The app must be free or purchased in volume. For more information on volume purchasing, see the following Apple documentation:
  • Mobile devices must have iOS 5 or later, or tvOS 10.2 or later and an MDM profile that supports managed apps.
    Mobile devices with iOS 5 or later that are enrolled with Jamf Pro automatically obtain an MDM profile that supports managed apps. For instructions on distributing an updated MDM profile that supports managed apps, see Self Service Web Clip.
The following table provides more detail about managed apps:
Unmanaged apps
Managed apps
Distribution Methods
Make available in Jamf Self Service
images/download/thumbnails/81923069/checkmark.png
Prompt users to install
Removal Options
Remove from Jamf Self Service
Remove from mobile devices
Remove when MDM profile is removed
Backup of App Data
Prevent backup of app data
App Update Options
Schedule automatic app updates
Force an app update
images/download/thumbnails/81923069/checkmark0.png
App Validation Options (in-house apps only)
Schedule automatic app validation
Force app validation
Converting an Unmanaged App to Managed
You can convert an app from an unmanaged state to a managed state after the app has been installed on a mobile device. Management occurs silently on supervised devices.
If the device is unsupervised, users are prompted to allow management. If the user declines to manage the app on their device, they are prompted to manage the app each time the device checks in with Jamf Pro until management is accepted.
  1. Log in to Jamf Pro.
  3. Click Mobile Device Apps.
  4. Click the app you want to convert from unmanaged to managed.
  5. Click Edit.
  6. On the General pane, select Make app manage when possible.
  7. Select Make app managed if currently installed as unmanaged.
  8. Click Save.
The app immediately becomes managed on supervised devices and will become managed on unsupervised devices when the user accepts the management prompt.
Managed Books
The following requirements determine whether a book can be managed by Jamf Pro:
  • The device has iOS 8 or later
  • The book is an in-house book, or a book available in the Book Store that is free or purchased in volume and assigned to the user via managed distribution (For more information, see User-Assigned Managed Distribution.)
If you try to make a book managed and these requirements are not met, the book behaves as unmanaged.
The following table provides more detail about managed books:
Unmanaged Books
(iOS and macOS)
Managed Books
(iOS only)
Install automatically/prompt users to install
Removal Options
Remove in-house books from mobile devices
Remove from computers
Remove in-house books when MDM profile is removed
When managed book requirements are met, the book is installed on iOS devices and users can view it with Apple Books. If you try to make an app managed but these requirements are not met, the app behaves as unmanaged.
