Supervision Identities
If you plan to supervise devices and deploy them using Apple Configurator 2 and Jamf Pro, you can use a supervision identity to pair supervised devices with multiple Apple Configurator 2 workstations that have the same supervision identity. A supervision identity can be applied to a device by pairing the device with an Apple Configurator 2 workstation or by enrolling the device with Jamf Pro using a PreStage enrollment configured with an Automated Device Enrollment (formerly DEP) instance that has a supervision identity.
A supervision identity certificate (.p12 file) can be created in Jamf Pro or created in Apple Configurator 2 and then uploaded to Jamf Pro. The identity can then be stored in Jamf Pro until you need to download it and add it to other Apple Configurator 2 workstations, or add it to an Automated Device Enrollment instance for use with a PreStage enrollment.
Note: To ensure devices are paired securely with each Apple Configurator 2 workstation, the workstations you are using must have matching supervision identities. If the wrong identity is applied to a device, the device must be wiped, re-supervised, and re-enrolled to change the identity.
For more information about supervision identities, see Apple's Configurator 2 Help documentation at:
https://support.apple.com/guide/apple-configurator-2/welcome
For step-by-step instructions on how to use supervision identities while deploying mobile devices using Apple Configurator 2, see the Deploying iOS and tvOS Devices with Apple Configurator 2 and Jamf Pro technical paper.
Requirements
To use supervision identities, you need:
  • Supervised devices with iOS 9 or later, or tvOS 10.2 or later
  • Apple Configurator 2.0 or 2.1
Creating a Supervision Identity
You can create a supervision identity in Jamf Pro for use with Apple Configurator 2.
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81533504/Icon_Settings_Hover.png .
  3. Click Mobile Device Management.
  4. Click Apple Configurator Enrollment images/download/thumbnails/11272205/Apple_Configurator_Enrollment.png .
  5. Click the Supervision Identities tab, and then click Edit.
  6. Click New.
  7. Configure the supervision identity using the fields on the pane.
  8. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Uploading a Supervision Identity
If you created a supervision identity using Apple Configurator 2, you can upload that identity to Jamf Pro so it can be accessed from other Apple Configurator 2 workstations or added to a Device Enrollment instance.
  6. Click Upload.
  7. Click Upload Supervision Identity and upload the supervision identity (.p12).
  8. Configure the supervision identity using the fields on the pane.
  9. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Downloading a Supervision Identity
You can download a supervision identity from Jamf Pro and add it to the Apple Configurator 2 workstations that you want your devices with the same supervision identity to trust.
  5. Click the Supervision Identities tab.
  6. Click View next to the supervision identity you want to download.
  7. Click Download.
  8. Click Done.
Adding a Supervision Identity to an Automated Device Enrollment Instance
When you add a supervision identity to an Automated Device Enrollment (formerly DEP) instance, that identity is applied to all devices enrolled using a PreStage enrollment that is configured with the Device Enrollment instance.
Note: Devices that are already enrolled with Jamf Pro and associated with an Automated Device Enrollment instance need to be re-enrolled to become associated with the supervision identity for that Automated Device Enrollment instance.
  3. Click Global Management.
  4. Click Device Enrollment images/download/thumbnails/11273193/Device_Enrollment_Program.png .
  5. Click the Automated Device Enrollment instance you want to add a supervision identity to.
  6. Click Edit images/download/thumbnails/81532686/edit.png .
  7. Select the supervision identity you want to add from the Supervision Identity for Use with Apple Configurator pop-up menu.
Related Information
