Simple Mobile Device Searches
A simple mobile device search functions like a search engine, allowing you to quickly search the items in your inventory for a general range of results.
The following table shows the items that you can search by and the attributes on which you can base each search:
Inventory Item
Searchable Attributes
Mobile devices
Mobile device name
Wi-Fi MAC address
Bluetooth MAC address
UDID
Serial number
Username
Full name
Email address
Phone number
Position
Department
Building
Room
Mobile device apps
Application name
You can also create an advanced search using detailed search criteria. These types of searches give you more control over your search. For more information, see Advanced Mobile Device Searches.
Search Syntax
This section explains the syntax to use for search functions. In general, searches are not case-sensitive.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. For more information about configuring account preferences, see Jamf Pro User Accounts and Groups.
The following table explains the syntax you can use for search functions:
Search Function
Usage
Example
Return all Results
Use an asterisk (*) without any other characters or terms, or perform a blank search.
Perform a search for “*” or leave the search field empty to return all results.
Perform Wildcard Searches
Use an asterisk after a search term to return all results with attributes that begin with that term.
Perform a search for “key*” to return all results with names that begin with “key”.
Use an asterisk before a search term to return all results with attributes that end with that term.
Perform a search for “*note” to return all results with names that end with “note”.
Use an asterisk before and after a search term to return all results that include that term.
Perform a search for “*ABC*” to return all results that includes “ABC”.
Include Multiple Search Terms
Use multiple search terms separated by a comma (,) to return all results that include those search terms.
Perform a search for “key*, *note” to return all results that begins with “key” and ends with “note”.
Exclude a Search Term
Use a hyphen (-) before a search term to exclude results that include the term.
Perform a search for “ABC*, -*note” to return all results with names that begin with “ABC” except for those that end with “note”.
Performing a Simple Mobile Device Search
  1. Log in to Jamf Pro.
  3. Click Search Inventory.
  4. Choose an item from the Search pop-up menu.
  5. Enter one or more search terms in the fields provided.
  6. Press the Enter key.
If you searched for an item other than mobile devices, you can view the devices associated with a result by clicking Expand images/download/thumbnails/81542993/Icon_Expand.png next to the result. You can also change the item on which the results are based by choosing an item from the pop-up menu at the top of the page.
Related Information
