Recurring Check-in Frequency
The recurring check-in frequency is the interval at which computers check in with Jamf Pro for available policies.
By default, the recurring check-in frequency is set to “Every 15 Minutes”.
Configuring the Recurring Check-in Frequency
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81532566/Icon_Settings_Hover.png .
  3. Click Computer Management.
  4. In the “Computer Management–Management Framework” section, click Check-In images/download/thumbnails/81532566/Check-In.png .
  5. Click Edit images/download/thumbnails/81532686/edit.png .
  6. Configure the recurring check-in frequency using the pop-up menu on the pane.
  7. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Each computer checks in at the specified interval, starting at the time the setting is applied to the computer. This means that check-in times will vary across computers.
Related Information
Policy Management
You can create policies that are triggered at the recurring check-in frequency.
Components Installed on Managed Computers
Find out where the files that control the recurring check-in frequency are stored on computers.
