Login and Logout Hooks
The Login/Logout Hooks settings in Jamf Pro allow you to create login and logout hooks on computers and use them to perform the following actions:
  • Log Computer Usage information (username and date/time) at login and logout.
  • Check for policies triggered at login or logout.
  • Hide the Restore partition at login.
Warning: Creating login and logout hooks with Jamf Pro can disable existing login and logout hooks.
Configuring Login and Logout Hooks
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81532578/Icon_Settings_Hover.png .
  3. Click Computer Management.
  4. In the “Computer Management–Management Framework” section, click Check-In images/download/thumbnails/81532578/Check-In.png .
  5. Click Edit images/download/thumbnails/81532686/edit.png .
  6. Configure the login/logout hooks settings using the checkboxes on the pane.
  7. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Related Information
