In-House App Maintenance Settings
You can use the App Maintenance settings in Jamf Pro to perform the following maintenance for in-house apps:
  • Automatic Updates—You can enable Jamf Pro to automatically update all in-house apps that are installed on mobile devices for the apps that were made available in Jamf Self Service for iOS. This allows you to update the apps without user interaction.
  • App Validation—App validation is the process of ensuring that the provisioning profile associated with an in-house app is still authorizing the use of the app. You can automatically validate all managed in-house apps on mobile devices by customizing how frequently Jamf Pro performs app validation.
    You can also manually force all devices to check in with Apple to validate installed in-house apps. This is useful if you know that devices may be offline for an extended period of time and you want to validate apps before the device is offline.
    The validation status for a managed in-house app on a mobile device is collected each time inventory information for the device is reported to Jamf Pro, and is displayed in the inventory information for that device. If an app cannot be validated, the validation status is reported as "not validated", and the app will not open until a successful validation occurs. For information about the situations in which an app may be reported as "not validated", see the Cannot Validate a Managed In-House App Knowledge Base article.
Enabling Automatic App Updates
  1. Log in to Jamf Pro.
  2. In the top-right corner of the page, click Settings images/download/thumbnails/81552791/Icon_Settings_Hover.png .
  3. Click Mobile Device Management.
  4. Click App Maintenance images/download/thumbnails/81552791/AppMaintenance.png .
  5. Click the In-House Apps tab, and then click Edit images/download/thumbnails/81532686/edit.png .
  6. Select Automatically update apps installed via Self Service.
  7. Click Save images/download/thumbnails/81531754/floppy-disk.png .
Configuring App Validation
  6. To enable automatic app validation, do the following:
    1. Select Automatically validate all managed in-house apps.
    2. Specify how often Jamf Pro attempts to validate apps using the Validation Frequency pop-up menu.
      You can choose to validate apps every week, every two weeks, every four weeks, or every eight weeks. The default validation frequency is "every week”.
  7. To force app validation, click Force Validation.
  8. Click Save images/download/thumbnails/81531754/floppy-disk.png .
