Advanced Volume Content Searches
Advanced volume purchasing content searches allow you to use detailed search criteria to search apps and books in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
As an alternative, you can quickly search volume content for a general range of results. For more information, see Simple Volume Content Searches.
Creating an Advanced Volume Purchasing Content Search
  1. Log in to Jamf Pro.
  2. Click Computers, Devices, or Users at the top of the page.
  3. Click Search Volume Content.
  4. Click New images/docs.jamf.com/10.22.0/jamf-pro/administrator-guide/images/download/thumbnails/80749134/Icon_New_Button.png .
    1. Click Add images/docs.jamf.com/10.22.0/jamf-pro/administrator-guide/images/download/thumbnails/80749134/Icon_Add_Button.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/docs.jamf.com/10.22.0/jamf-pro/administrator-guide/images/download/thumbnails/80749134/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menus to specify the relationships between criteria.
    images/docs.jamf.com/10.22.0/jamf-pro/administrator-guide/images/download/attachments/80749134/VPP_Advanced_Search.png
  10. Click Save images/download/thumbnails/81531754/floppy-disk.png .
The results of a saved search are updated each time content is modified and meets or fails to meet the specified search criteria.
To view the search results, click View images/docs.jamf.com/10.22.0/jamf-pro/administrator-guide/images/download/thumbnails/80749108/preview-content.png . You can export the data in your search results to different file formats. For more information, see Volume Content Reports.
