Advanced Mobile Device Searches
Advanced mobile device searches allow you to use detailed search criteria to search for devices in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced Mobile Device Search
  1. Log in to Jamf Pro.
  3. Click Search Inventory.
  4. Click New images/download/thumbnails/81543005/Icon_New_Button.png .
    1. Click Add images/download/thumbnails/81543005/Icon_Add_Button.png .
      Note: Only your 30 most frequently used criteria are listed. To display additional criteria, click Show Advanced Criteria.
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/81543005/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menus to specify relationships between criteria.
    images/download/attachments/81543005/AdvancedSearchWithReports.png
  10. Click Save images/download/thumbnails/81531754/floppy-disk.png .
  11. To view search results, click View images/download/thumbnails/81543005/preview-content.png .
    The results of a saved search are updated each time mobile devices contact Jamf Pro and meet or fail to meet the specified search criteria.
  12. (Optional) To export the search results, click Export and follow the on-screen instructions.
Related Information
