Simple Volume Purchasing Content Searches for Mobile Devices
A simple volume purchasing content search functions like a search engine, allowing you to quickly search the mobile device apps and books in Jamf Pro for a general range of results.
Volume purchasing content searches are based on the name of the app or book you are searching for and display the following information:
  • Name of the app or book
  • Location used to purchase the content
  • Type of content
  • Total content that has been purchased with the volume purchasing location
  • Number of apps or books assigned to mobile devices, computers, or users
  • Number of volume assignments that the content is associated with
Search Syntax
This section explains the syntax to use for search functions. In general, searches are not case-sensitive.
Note: The default search preference is “Exact Match”. For most items, the option can be changed to either “Starts with” or “Contains”. For more information about configuring account preferences, see Jamf Pro User Accounts and Groups.
The following table explains the syntax you can use for search functions:
Search Function
Usage
Example
Return all Results
Use an asterisk (*) without any other characters or terms, or perform a blank search.
Perform a search for “*” or leave the search field empty to return all results.
Perform Wildcard Searches
Use an asterisk after a search term to return all results with attributes that begin with that term.
Perform a search for “key*” to return all results with names that begin with “key”.
Use an asterisk before a search term to return all results with attributes that end with that term.
Perform a search for “*note” to return all results with names that end with “note”.
Use an asterisk before and after a search term to return all results that include that term.
Perform a search for “*ABC*” to return all results that includes “ABC”.
Include Multiple Search Terms
Use multiple search terms separated by a comma (,) to return all results that include those search terms.
Perform a search for “key*, *note” to return all results that begins with “key” and ends with “note”.
Exclude a Search Term
Use a hyphen (-) before a search term to exclude results that include the term.
Perform a search for “ABC*, -*note” to return all results with names that begin with “ABC” except for those that end with “note”.
Performing a Simple Volume Purchasing Content Search
  1. Log in to Jamf Pro.
  3. Click Search Volume Content.
  4. Enter one or more search terms in the field provided.
  5. Press the Enter key.
Viewing the Mobile Devices that Content is Assigned To
You can view the mobile devices that content is assigned to.
    A list of content is displayed.
  6. To view the mobile devices that the content is assigned to, click the number displayed in the In Use column.
    The mobile devices that have the content assigned to them are listed on the Mobile Devices pane.
Viewing the Volume Assignments that Content is Associated With
You can view the volume assignments that content is associated with.
  6. To view the volume assignments that the content is associated with, click the number displayed in the Volume Assignments column.
Related Information
