Advanced Volume Purchasing Content Searches for Users
Advanced volume purchasing content searches allow you to use detailed search criteria to search mobile device apps, Mac App Store apps, and books in Jamf Pro. These types of searches give you more control over your search by allowing you to do the following:
  • Save the search.
Creating an Advanced Volume Purchasing Content Search
  1. Log in to Jamf Pro.
  2. Click Users at the top of the page.
  3. Click Search Volume Content.
  4. Click New images/download/thumbnails/81533658/Icon_New_Button.png .
    1. Click Add images/download/thumbnails/81533658/Icon_Add_Button.png .
    4. Enter a value in the Value field or browse for a value by clicking Browse images/download/thumbnails/81533658/Browse_icon.png .
  7. Choose an operator from the And/Or pop-up menus to specify the relationships between criteria.
    images/download/attachments/81533658/VPP_Advanced_Search.png
  10. Click Save images/download/thumbnails/81531754/floppy-disk.png .
The results of a saved search are updated each time content is modified and meets or fails to meet the specified search criteria.
To view the search results, click View images/download/thumbnails/80749108/preview-content.png .
Viewing Advanced Volume Purchasing Content Search Results
  4. Click the advanced volume purchasing content search you want to view the results for.
  5. Click View images/download/thumbnails/80749108/preview-content.png .
Related Information
