Remote Commands for Mobile Devices
The remote commands available in Jamf Pro allow you to remotely perform tasks on a mobile device.
You can send a remote command to a single mobile device. Some commands can also be sent to multiple devices at once using mass actions. For more information, see Performing Mass Actions for Mobile Devices.
Note: The remote commands available for a particular device vary depending on the device ownership type, device platform, device type, and OS version. For more information, see Mobile Device Management Capabilities.
The following table describes the remote commands that you can send from Jamf Pro:
Remote Command |
Description |
iOS Device Requirements |
Personally Owned iOS Device Support |
Update Inventory |
Prompts the mobile device to contact Jamf Pro and update its inventory |
Lock Device |
Locks the mobile device If the mobile device has a passcode, the user must enter it to unlock the device. (Optional) Displays a message on the mobile device when it locks. This message is only sent if the mobile device has a passcode. (Optional) Displays a phone number on the mobile device when it locks. The phone number is only displayed if the mobile device has a passcode. |
Clear Passcode |
Removes the passcode from the mobile device If a configuration profile with a Passcode payload is installed on the device, the user is prompted to create a new passcode. Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared, you must put the device in DFU mode to disable Lost Mode. |
N/A |
Clear Screen Time Passcode (This command was previously called Clear |
Removes the Screen Time passcode from a device |
Update Passcode Lock Grace Period |
Sets the amount of time that a device's screen can be locked before requiring a passcode to unlock it. |
N/A |
Unmanage Device |
Stops communication between the mobile device and the Jamf Pro server, which means you can no longer perform management tasks on the device When you unmanage a device, the following items are removed from the device:
Note: Although an unmanaged device will no longer submit inventory, its inventory record remains in Jamf Pro. |
N/A Note: Only personally owned mobile devices enrolled using User Enrollment can execute the Unmanage Device command.
Wipe Device |
Permanently erases all data on the device and deactivates the device. This command is available for both iOS and Apple TV devices (tvOS 10.2 or later). Optionally, you can:
Note: Wiping a device does not remove the device from Jamf Pro or change its inventory information. To restore the device to the original factory settings, you must manually reactivate the device. |
N/A |
Restart Device |
Restarts a device. This command is available for both iOS and Apple TV devices (tvOS 10.2 or later). (Optional) Clears the passcode on the device. If this option is chosen, the Clear Passcode command is sent to the device before the device is restarted. Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared using the Clear Passcode command, you must put the device in DFU mode to disable Lost Mode. |
N/A |
Send Blank Push |
Sends a blank push notification, prompting the device to check in with Apple Push Notification service (APNs) |
Set Wallpaper |
Sets an image or photo as wallpaper for the Lock screen, Home screen, or both screens on a supervised device You can upload an image file or choose an existing image file. |
N/A |
Enable/Disable Voice Roaming Enable/Disable Data Roaming |
Enables/disables voice or data roaming on the device Note: Disabling voice roaming automatically disables data roaming. |
N/A |
Update OS Version |
Updates the OS version on supervised devices You can update the OS version for iOS or tvOS devices using the following options:
Note: Updating to a specific OS version requires iOS 12 or later and tvOS 12.2 or later.
Note: This option applies to iOS devices only. This command is only available as a mass action. For more information, see Performing Mass Actions for Mobile Devices. For more information, see the Updating iOS Best Practice Workflow for Jamf Pro. |
N/A |
Log Out User |
Logs out the currently logged in user for Shared iPad only |
N/A
Enable/Disable Lost Mode |
Enables/disables Lost Mode on the device Lost Mode locks the device and displays your custom messaging on the device's Lock screen. Global Positioning System (GPS) coordinates for the device's approximate location are also displayed in the inventory information for the device. Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared using the Clear Passcode command, you must put the device in DFU mode to disable Lost Mode. |
N/A |
(Optional) Always enforces Lost Mode on the device. This option ensures Lost Mode is enabled after an enrollment event has completed. When selected, Lost Mode can be only disabled in Jamf Pro. (Optional) Plays a sound on the lost device. Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared using the Clear Passcode command, you must put the device in DFU mode to disable Lost Mode. |
N/A |
Update Location |
Updates the GPS coordinates collected for a mobile device in Lost Mode |
N/A
Enable/Disable Diagnostic and Usage Reporting Enable/Disable App Analytics |
Enables/disables the sending of diagnostic and usage data to Apple Enables/disables the sending of app analytics data to Apple Note: Disabling diagnostic and usage reporting automatically disables app analytics. |
N/A
Shut Down Device |
Shuts down the device (Optional) Clears the passcode on the device. If this option is chosen, the Clear Passcode command is sent to the device before the device is shutdown. Important: If a device in Lost Mode shuts down or restarts and the passcode is not cleared using the Clear Passcode command, you must put the device in DFU mode to disable Lost Mode. |
N/A |
Enable/Disable Bluetooth |
Enables/disables Bluetooth on the device |
N/A |
Set Activation Lock |
Enable Activation Lock directly on a device Disable and prevent Activation Lock For more information, see the Leveraging Apple's Activation Lock Feature with Jamf Pro Knowledge Base article. |
N/A
Manage Jamf Parent |
Allows you to remove app restrictions set by Jamf Parent on students' school-issued devices or remove Jamf Parent management capabilities. Removing Jamf Parent management capabilities prevents Jamf Parent from managing the student device until the parent scans the QR code again. To remove Jamf Parent restrictions on student devices, you need a Jamf Pro user account with the "Remove restrictions set by Jamf Parent" privilege. For more information, see Integrating Jamf Parent with Jamf Pro. |
Supervised |
N/A |
Refresh Cellular Plans |
Refreshes a device’s cellular plan by querying a carrier URL for active eSIM cellular plan profiles Note: The device and carrier must support eSIM. For more information, see the following article from Apple's support website: |
iOS 13 or later |
N/A |
Personally Owned Devices Only |
Wipe Institutional Data |
Permanently erases institutional data and settings on the device On a personal mobile device, the following items are removed:
On personal mobile devices, the Wipe Institutional Data command makes the device unmanaged. This stops communication between the device and the Jamf Pro server, which means you can no longer perform management tasks on the device. Note: Although an unmanaged device will no longer submit inventory, its inventory record remains in Jamf Pro. |
Note: Only personally owned mobile devices enrolled using Personal Device Profiles can run the Wipe Institutional Data command. |
Sending a Remote Command
Log in to Jamf Pro.
Click Devices at the top of the page.
Perform a simple or advanced mobile device search.
For more information, see Simple Mobile Device Searches or Advanced Mobile Device Searches. -
Click the mobile device you want to send the remote command to.
If you performed a simple search for an item other than mobile devices, you must click Expandnext to an item to view the devices related to that item.
Click the Management tab, and then click the button for the remote command that you want to send.
Depending on the command selected, additional options may be available.
The remote command runs on the mobile device the next time the device contacts Jamf Pro.
Viewing the Status of Remote Commands
Log in to Jamf Pro.
Click the mobile device you want to view remote commands for.
Click the History tab.
Use the Management History pane to view completed, pending, or failed commands.
Canceling a Remote Command
Log in to Jamf Pro.
Click the mobile device for which you want to cancel a remote command.
Click the History tab, and then click Pending Commands.
Find the command you want to cancel, and click Cancel across from it.
